A couple of nitrous questions...
I just bought a Zex kit with the remote opener, warmer, window switch, LED purge kit, and cup holder switch. My question is I just talked to Doug at bama chips and he wrote a 93 race tune for me a few months ago and says that the tune will work up to a 100 shot and to just make sure and set the window switch for an RPM of 2500-5900. Has anyone else ran one of his tunes on a 100 shot of nitrous? What would I need to do if I decided to go up to a 125-150? Anyone with similar set ups please let me know how it runs for you...btw 06 gt and thanks.
wet or dry?
I wouldnt run nitrous unless I didn't care if I blew it up, people swear up and down by it until it blows, you have a nice car... thats my fair warning.
that said 100 wet shot be perfectly safe, for a dry shot youll need a tune
By the time you 2500 rpms the timing has been advanced as much as it will go so the 100 shot will be safe. If you go to a 125 you need to take 2 degrees of timing out. If you don't want to get it retuned just get a timing adjuster and retard it that way.
lol, first you tell him that in your opinion his car is going to blow up.... then in your second line you tell him a 100 shot is perfectly safe?
you obviously can't get your facts straight but at least get your own opinion straight?
n2o is a more than safe power adder with a dyno tune. it is extremely important to know your air fuel ratio while on spray before you just go spraying all the time. i would never spray without a dyno tune first, there is just no way of knowin whats going on without it.
"meant in a real world sense"... what does that mean? in your world it is not safe?
excuse me for commenting.... i guess i should just shut up and let people like you give people the wrong ideas. give him the FACTS and let him decide on his own.
Booya! Lol.
Go with a wet kit, use a window switch, activate the nitrous at 3000 rpms and shut it off at 5800. Spray it with a 100 shot and you have nothing to worry about. No tune needed for that.
Thanks for all the replies guys, I really do appreciate the imput. I think I'll keep the tune I have on it adjust the timing back just a touch add the colder plugs that came with it and then see how it runs if I don't like it I'll take it to the tune shop get a pro tune and dyno done. Thanks again
lol, either way, whether you say it CAN be or it IS... the point is, if the correct precautions are taken, it is a SAFE way to make power.
I can't count many blown motors Ive seen from "safe" nitrous systems....
see you on the side of the road have a nice day
