Turbo ?
Turbo ?
so I'm starting to piece my 90 5.0 turbo system together.. So far I have afr165 heads trickflow r intake a masterpower t70 turbo and intercooler 60# injectors fuel regulator and 255 fuel pump.. Will all that work fine together? And as far as ignition bov/wastgate what do should I get. Anything else I need to know or that I'm forgeting let me know. Thanks for the help
I 2nd the Tial stuff it is real nice stuff. I have just been running the stock ignition. all but the coil and I don't think it makes a bit of difference but I have been 10.30 and well into 18psi of boost.
yeah I have heard alot of good things about tial products. What size bov would work best with my setup. And should I place the bov before or after the turbo... Also what do you mean by "window switch" or "pills"
What size turbo and how much boost are you planning on running? I'm not very familiar with mustang FI (I'm a honda guy obviously) but that info will be needed in order to be able to see what size needs run. I'd say probably a 44mm gate. You have to place the blow off valve after the the turbo somewhere on the the piping. The reason you need a blow off valve is to prevent compressor surge. That happens when your throttle plate closes and all that boost has no where to go except back to the turbo causing it to stop spinning which is bad for the turbo, and hurts your performance because the turbo can't stay spinning in between shifts. A BOV wouldn't do anything if it was placed behind the turbo.
Sorry I ment to ask should I put the bov before or after the intercooler or does it matter. i have a masterpower t70 turbo And plan on running 8 to 10# but also want to up it a little if I go to the track. Also around what rwh should I be putting out with 8# of boost. Thanks
a pill is a set rpm for msd boxes.buy one pill at 5500rpm and one at 2500.if you want to change that rpm you will have to buy more pills.
o yah . as long as the bov is before the mass air meter it doesnt matter where it goes. after the meter. (the pipe from mas meter to t.b) the air is already metered. so it can cause a rich situation when the blow off releases air
