Intercooler!
Intercooler!
Ok the s281 engine i have has the series 2 blower ontop with a radiator between it and the intake manifold, this radiator has tubes that are supposed to connect with a second radiator/intercooler which will be hooked up to an overflow tank and a pump, obviously. all im looking for is the intercooler pump and overflow tank. where can i find an intercooler for my application (96 gt) ? ive looked everywhere, and i dont need an aftercooler, but i do need the pump and overflow tank. thanks!
RE: Intercooler!
Go to http://www.modularpowerhouse.com/forums/index.php and ask your question there. You have a a better shot at getting it answered.
RE: Intercooler!
ORIGINAL: matthockey32
you mean an air-air aftercooler?
RE: Intercooler!
ORIGINAL: mustang_montana
yeah its air/water. air/air just aint doable. its getting to the point where i might just get the 8psi pully and run it without the intercooler untill i figure something out.
RE: Intercooler!
ORIGINAL: FoxGT
You definetly shouldn't skip this part. The intercooler will add alot of power. Running an intercooled 5psi setup would put out the same power as a 8psi non intercooled setup.
if you don't do it for power do it for safety
