New turbo coming...header suggestions??
So i have a 76mm single turbo going on my 02 Saleen and I need to know what shorty headers I should put on. Was looking at the Ford Racing headers and the JBA. Help...
The stock manifolds are one piece cast iron, so they will never crack. Tubular headers will dissipate heat rather than retaining it like stock, and heat helps to spool the turbo faster. I actually had a set of BBK headers, but decided not to use them after researching it a bit. There have been tests where shorty headers lost a few hp compared to the stock manifolds. Longtube front facing headers will make more power for a drag setup and big turbo, but that usually requires a whole custom fabricated kit
Heat is not a good thing, you want air flow - faster/more cfm will spool the turbo faster. It is true that hot air expands... yadda yadda... but thats not what is going to spool the turbo and will only shorten the life of your turbo and lead to higher IATs. Load will spool the turbo. Back pressure is a turbos arch nemesis. Running shorties would be better, but im wondering what kit he is ordering... it needs to be able to match up properly.
http://www.tercelreference.com/terce...st_theory.html
http://en.wikipedia.org/wiki/Turbocharger
there may be some advantage to manifolds on a 4.6 do exhaust gas velocity because of the unique crappiness of the PI head. However, a turbo is not heat driven, it is velocity driven and more heat does not equal more power, or a faster exit velocity - at least in the sense that it makes sense to add heat, because all heat added on one end = a reduction of power on the other.
