will my setup hadle a 75 dry shot!
I have a dry nos kit waiting to be put on I installed a walboro 255lph fuel pump and some ngk tr6 plugs that are one step colder I have the stock 24lb injectors, will this setup handle a 75 dry shot safely or do I need to upgrade injectors? I really don't want too will 24s be fine?
75 shot on an 8cyl is normally no big deal so I would say no problem. but, like the other 500 viewers wouldn't want to be responsible for you breaking something. I would start by reviewing the guidelines in the install instruction & the FAQ's on the manufacturer's home page.
And, make sure to adjust your timing per the install instructions.
Should be more than enough for a 75 shot. Lethal Perf offers the NOS universal fogger kit for your car.
Here is the installation manual pdf. I would read both so you .know what is involved
oh hellz yes your good to go
those ngk's are NOT platinum are they ?
gap them about .046"
yes... all stock fuel system on any v8 mustang will handle a 100 shot. a 190 or better pump is a good idea, but your fuel system will support a true 400 hp
start off using 89 octane and 10* timing (if its under 80*), at the track bump timing in 2* increments till you slow down ( MPH....not ET) note the weather too for your own notes
fyi i have run as hot as 14* timing on 87 octane with 100 shot dry kit, but thats pushing it... i just know my car well enuff and can on cool nights
