Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
borla atak rubbing on tire?!?!
Old 05-09-2016, 08:44 AM
Matt Stryder
Matt Stryder's Avatar
Default borla atak rubbing on tire?!?!
I've been having issues with my atak system rubbing the rear tire on my gt. I've tried realigning it several times and even use my impact to tighten the hardware but the passenger side still keeps moving. I cant weld it in because im running an OR xpipe and need to do emissions every 2 years......any ideas? he is a list of mods on the car
Borla ATAK
OR X-pipe
cobra reps F245-45-17 R315-35-17
cross drilled and slotted rotors
Eibach pro coilover suspension
UD pulleys
JLT carbon intake
k&n 8" filter
accufab intake elbow with 80mm throttle body and spacer
a/c deleted
Matt Stryder is offline
Old 05-10-2016, 09:30 AM
Matt Stryder
update**
found out that the exhaust is hitting the sway bar and forcing it into the tire. anyone know of a company that makes sway bar relocation brackets for the sn95? all I can find is 05-15 brackets
Old 05-10-2016, 11:47 AM
jwog666
jwog666's Avatar
are you sure you have this installed correctly, they wouldnt design an exhaust that hits the swaybar. and as far as i know there is no such thing as a relocation bracket
jwog666 is offline
