View Poll Results: Which mustang is the best?
noroof66
23
20.72%
Mustang3GT07
44
39.64%
foolio2k4
15
13.51%
dukeme
17
15.32%
2007CalSpec
12
10.81%
Voters: 111. You may not vote on this poll
ROTM February!
#21
1993 Mustang Notcback 393 Bennett racing motor
Thanks for the consideration guys...
Specs-
Bennett Motor # 101116
393 Cubic Inch / 2 Bolt Main Block 8.8 to 1 Compression
Scat H-Beam Rods
Probe Forged 4340 Crank
Diamond Pistons Job # 31421
32cc Dish
4030 Boro
6200 Rod
GT-40 intake
Vortech s trim supercharger with small pulley
V-1 #14553 D-213-16
Victor Jr. Aluminum Heads
1.6 Roller Rockers
Ford Motor Sport 65MM T.B. & Spacer
Griffin 2 1.15 Aluminum Core Radiator
Bennett Custom Grind Cam
Lift .577 to .577
Duration @ .050 230-242
116* Lobe Separation
Full Aeromotive Fuel system
Viper Spec T-56 6 Speed
Spec 3 clutch / Short Shifter
Aluminum Drive shaft
Hurst line lock
BBK Sporty Headers / BBK High Flow Cats
Flowmaster 2 chamber mufflers, polished tail pipes
Suspension / Body
AJE K-Member
Upper/Lower Control arms Chromoly
Welded in sub frame connectors
Energy suspension motor mounts
Energy transmission mounts
175# Strange Coil Overs
Strange 10 way adjustable struts
MM Aluminum Caster camber plates
Rear End
Upgraded rear 8.8
Welded rear at weak points
Ford Motorsports Rear girdle
Ford Motorsports 373 Gears
Specs-
Scat H-Beam Rods
32cc Dish
4030 Boro
6200 Rod
GT-40 intake
V-1 #14553 D-213-16
1.6 Roller Rockers
Lift .577 to .577
Hurst line lock
Suspension / Body
AJE K-Member
Rear End
Upgraded rear 8.8
#25
#29
