Not sure what to get :/
True, but in the end I really dunno what to get and in what way it will affect my car since its a DD. Guess I will need to do more research :/
Just would like to know the best that I can currently get
For a DD where you are definitely not going to do substantial lowering, shocks/struts are enough of a starting point for suspension tinkering. LCAs maybe, depending on whether you have a wheel hop issue (and if it's a mild case, GT500 LCAs may be enough). No need for much else unless your axle is already way off from being centered.
Give Sam Strano a call.
Norm
Thanks for your help everyone once again. I was looking around and found this:
http://store.roushperformance.com/detail.aspx?ID=772
Ford Mustang Wheel Hop Reduction Kit
PN: 401788
Seems easy enough, but its a pain to install - especially in cold weather.
As everyone suggested I may just go small for now and then go bigger later on. First shocks/struts and LCAs (since I already have them), then springs, and so on.
Going on that note, I may go with the roush shocks (stage 2) - saw they had pretty decent reviews and I could get them for pretty cheap.
PN: 401788
Well, this settles it...(hopefully)
I am picking up a Roush Stage 2 kit with everything for a very, very nice price from a friend ($600 for everything - only had it on his car for around 1000mi and he went to the stage 3 instead (had a S/C)).
Hope its all cut out to be :/ ...
Get these parts installed. Upgrade your brake fluid and pads and you are ready for Pocono
