S197 GT Spring Rates and Heights (no guessing allowed)
#21
A spring rate is how much force needs to be applied to compress the spring through a given distance. If you have a 134 lb per inch spring, then it will take 134 pounds to compress the spring 1 inch. It let's you know how firm or soft the ride will be.
#22
Hey, just found this chart too, might have some useful info to add to the one started here:
http://www.hawaiiperformancemustangs...?topic=14492.0
#23
i got it thanks man
#28
#29
spring manufacturers,
so on top of all these spring rates and drop amounts, how about the manufacturers ? Anyone have a bad experience ? I have a friend who had some Eibachs that his friend pulled out of his S197 V6. He gave them to me to try on my wife's car, it sat right down on the bump stops, they were completely sacked. So how does that happen ? Do all lowering springs just finally compress down to nothing after a while ? I bought a set of Teins about 2 years ago, same thing, the guy said he pulled them out to trade his car in with the stock ride height. Put them in, car sat on the bump stops in the rear.
Who's had their lowering springs in for a while with no settling or problems? It's not that big of a job putting springs in, but I don't want to do it again.
How about Dropscene ? Anyone have experience with them ?
#30
Ive heard that the GT sits a little lower then the v6. I have a v6 and am looking into the amount of drop from the different manufactures. does anyone know if this is true and if so what that difference is?
