Need a lil help tightening up suspension
Love your Steeda!!!
Off Topic question. Does your front splitter move up if you grab hold of it and lift - gently?
Mine does and I am not sure it should. I get about 1/2 inch movement up from the normal at rest position. I am big about no squesk, noises and unnecessary movement. Bugging me a bit. I would assume a higher speeds it would move from the force of the wind.
Sorry for the highjack.
My Steeda Q350 is a much shorter list than yours! Working on it though.
Nice list of mods and Great - Beautiful looking Stang!
The bottom lip is painted black. I think. There are only 2 front splitters from Steeda. The one I have and then the one with the fog lamps or brake air duct kit.
Could be someone elses but if it is a serialized Steeda then it the same one I have.
Oh also there is a fibergalss one and an ABS one. I have seen several Steeda's with the lip being painted like that. Looks Bad A$$!
Have to check with the OP.
Yep I do! I've done a bunch of changes to the suspension, some things twice, and have ended up with what I think to be the best combination of parts for "me". (Steeda Sport springs, Koni yellows, Fays2 Watts Link and Strano front/rear adjustable sway bars) That certainly might not be the best for someone else, but it works for me! Putting in the watts link was a night and day difference in the overall way the car rides and handles. With the equipment list on your car it should be a very noticeable improvement. I'd recommend finding someone who has installed them before and can help you tune it after the install. Sam Strano was a huge help with parts and advice.
