Adjustable rear spring seats
I would think twice before calling sam out agian.....that wasnt very cool
Thanks Sam. I see...so my steeda comp rears would not be compatible with the coilover seats. Figures. Not a problem since I'm already mixing ultralite front and comp rear springs. It would probably be a plus to have the ability to tune the rear rates anyway.
Just checked Steeda's spring variety. 163 and 175#, which I believe is what the steeda comp rears are (175). So $169 for the seats and $139 for the springs...this may be worth the upgrade.
I'm having an issue where I bottom out onto the bumpstops pretty hard over some deep dips in my area. My car currently sits nearly completely level front to rear. I assumed I could raise the rear slightly via the coilover adjusters and solve this problem along with leveling the rear. I also wouldn't mind a 1/2'' front/rear rake. Am I wrong about this? Do you think this would be a good idea Sam?
Details.. they don't matter, do they?
I installed Steeda Ultralite springs not too long ago and now my car has more rake to it. It used to be more level when I had Tein H-Tech springs. How is your car almost level with the Steeda comp rear springs? I would think my car should be more level than yours since the Ultralite rears are 1.5" compared to the Comps 1.25". Am I missing something here?
Did steeda misjudge their comp rear springs? Maybe. They looked shorter than the ultralite rears sitting side by side. The comp rears are very small, light springs, but with a better rate IMO. I may have a pic, I'll search for it.
Aha, found it. Now take a look at this comparison and tell me the comp rear don't lower more than the ultralite rears. And they're probably 1/2 the weight of the 'ultralite' rears. Look how larger the ultralite rears are! The comp rears are a much better spring IMO, in both weight and function. The ultralite fronts were MUCH lighter weight than the comp fronts so go figure. They work great together.
The steeda ultralite set:
And the steeda comp set:
You can see from the pics the larger coil (and weight) of the front steeda comps. And the shorter height (and weight) of the comp rears. The lite fronts were several lbs lighter than the comp fronts and the comp rears were a few lbs lighter than the lite rears. I prefer the more linear rate of the comp rears. The bit of higher rate on the comp rears causes less 'bounce' and very nice road feel combined with better response (due to weight/rate?).
I don't know what to tell you. My car has always had an issue with the front riding a bit high. With the full set of competition springs it ran 1/2'' higher up front. I've asked others with the competition spring set and they reported the same thing. It may have something to do with the steeda HD camber plates. I don't know. All I do know is with the ultralite fronts and competition rears it's nearly level, maybe 1/4'' front to rear.
Can you do me a favor and measure the distance from the middle of the rear fender lip to the ground and I'll measure mine? I'd like to compare your rear height on comps and my rear on ultralites.
Just went out and measured. I'm exactly 27.5 front, 27.5 rear on the drivers side and 27.7-8 front and 27.7-8 rear on the passenger side. Not sure if my garage floor throws off the passenger measurement or if the full tank of gas has an effect on it but there it is. I'd like to use the spring seat adjusters to get a bit more rake (and rear travel) out of it. 1/4'' would be ideal.
I agree with your other statements and was the reasoning behind my purchase of the ultralite springs. I wasn't unhappy with the complete Comp spring set. I was thrilled with them but grew tired of everyone saying my car sat higher in front. No pics but it was 1/4-1/2'' higher in front than rear. Very noticable.
If you want to try the comps, spend the $169 for the rear adjusters along with the $139 coilover spring of choice instead of purchasing an entire comp spring set. You would get the adjustability and ability to change rear spring rates. I'm either taking that route or a full coilover setup. Still gathering info...
You also have a bit more weight over the front with the s/c so that could be affecting the ride height. The nice thing about springs is you can always resell them. I've tried H&R Race, H&R Sport, Steeda Comp and Steeda Ultralite. They've all resold rather quickly. I'm apprehensive about the ground control setup with eibach springs. I see they don't list rates, only sport/aggressive. I'm not big on eibach products and feel more comfortable with steeda. None of their products have ever let me down and I have plenty of their stuff on my car. I'm actually really happy with my spring setup/rates at the moment but want to replace the dampers.
I plan to swap the d-spec's to something else soon. I'm not happy with the rebound/compression adjustments. It's just a matter of weighing my options of dropping $800 on a set of Koni's along with the adjustable steeda rears for another $300. I'm nearing coilover expense at that point and would rather spend another couple hundred on a coilover setup but it won't be ground control. I've heard good things about the H&R clubsport setup as well as KW's offerings.
