Rear end feels 'loose'
i'll be the first to admit i don't know much about suspensions, so i'll see what you all think . for a while now, it kind of feels like my rear end is 'jumpy' or 'loose'; driving down a relatively 'flat' road can, at times, feels like i'm driving during an earthquake. if i hit a minor 'bump' or something, it feels like my rear end jumps either to the left or the right. i never lose traction or anything, but there is enough of a jump that it makes me think something isn't right.
i've got an 05 gt with ~24k miles, and the only 'upgrades' i've made to the suspension so far are bmr lca's (they probably have around 10-12k miles on them and are greased ~ every 3000k miles). i checked the bushings on the lca's to make sure they weren't busted, and they appear fine. i also looked underneath to see if there were any cracks, broken bushings, etc. on any of the oem parts, and i didn't notice anything (but like i said, i'm not an expert on this).
so, i guess i'd like to know if anyone knows of something specific to look for for a problem like this, if it could by my shocks going out, or if there are any parts i could upgrade to that might help solve an issue like this.
thanks
thanks
The panhard bar ends that are not seen until removed...
You cant check them visually on the vehicle (there
is a plastic cover over one end...).
Replace them with PolyBushings FTW.
The Panhard keeps the rear end centered...
i knew you'd have an answer (and i'm glad you did ). the shocks were my first guess, but i was hoping they weren't 'bad' since they have a fairly low amount of miles on them... but they are at least 5 years old and i'm not really sure how much of a factor an age like 5 years could be on something like shocks. do you have any personal recommendations/suggestions on which brand of shock would work best for a daily driver; i don't do any kinds of racing or anything
if this could be the case, do you think it is something an amateur like me could do, or should i take it to a shop?
thanks
thanks
and easily replaced them with Prothane Poly bushings available
at www.mossmuscle.com - search 'prothane'. In the driveway
with no jack none the less. Just remember to do the final tightening
of the fastners at suspension ride height and not suspension fully
extended up on a jack...
Its a real cheap upgrade and keeps the rear end centered nicely.
055-102 $16.00 Prothane Bushings - Rear Tacking Arm
And cheap to boot...
Dont just stop there, prothane the carp out of your stang.
You will be glad you did.
Front the front/rear sway bar bushings to the motor mounts to the
shifter bushings, its all good (and a cheap upgrade you do at home).
Not that Sam needs me backing him up, but this is the right thing. I called Sam up a while ago with the same concerns. I thought something like a Watts Link ($650 part) that kept the axle from shifting while it moved was the way to go. He suggested a pair of Koni STR.Ts ($150) instead. I couldn't have been happier with the results. Before I even got the car out of the driveway I could feel the difference. I don't have that skittish jumpy side to side kick feeling any more, and the car feels much more composed at all times now.
