Coil-over/Suspension question
Old 05-09-2012, 08:39 PM
2005Redfire6
2005Redfire6's Avatar
Default Coil-over/Suspension question
Hey guys,
Currently my suspension setup consist of the following: Stock V6 front sway bar, steeda adjustable end-links, Koni STR.Ts, Eibach pro kit, BMR PHB, BMR LCAs, BMR LCA relocation brackets, UMI adjustable UCA, and a k-member brace. This car is primarily going to be going in a straight line and I want to set it up better to do so but at the same time I want it to handle well. Here is my questions:
I want to go with a coil-over setup for a few reasons: I have a drag wheel/tire setup that consist of skinnies and with my current drop the chin spoiler is what seems like centimeters from the floor with the skinnies mounted. With a coil-over setup I would be able to lift it up in the front during track days for obvious reasons, also its my understanding coil-overs will be a lot stiffer then what I have now which is what I am looking for. I will also get camber plates with the coil-overs if they don't come with them.
Which coil-overs would you all recommend if all I want to do is adjust ride height and will give me a good amount of stiffness? I have been looking at the ST coil-overs on Strano's site as an option or the H&R street performance kit which I hear is really stiff. I am also thinking about going with Strano's 35mm front bar and chromoly rear sway bar, let me know what you think!
PS. Please don't tell me to contact Sam Strano for his recommendations, I've tried twice on here with no response.
2005Redfire6 is offline
Old 05-11-2012, 11:15 AM
tr3flip
tr3flip's Avatar
For a coilover with height adjustments only the Eibach Pro Street S kit seems to be the best bang for your buck. They're mono-tube and hand assembled at Eibach USA which means the shocks can easily be serviced if ever needed. This is an overall very balanced package. Maximum Motorsports also offers a camber plate option for them as well.
tr3flip is offline
Old 05-11-2012, 08:07 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Originally Posted by 2005Redfire6
Hey guys,
You don't want to go too stiff or you'll lose your straight line grip. You'll want adjustable dampeners which you can stiffen up on the street but soften up for the strip. Since it sounds like you're pretty serious about drag racing, I'd certainly consider QA1 shocks and struts. They're less expensive than the popular coilover kits and they work as well or better on the dragstrip.
If you'd like to give us a call at UPR, we'd be happy to get into more specific details with you about it. 561.588.6630
www.uprproducts.com
UPRSharad is offline
Old 05-14-2012, 10:23 AM
2005Redfire6
Thanks for the responses guys.
Old 05-17-2012, 04:15 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
No problem!
Old 05-23-2012, 02:37 PM
SteedaBrandon
Former Sponsor
SteedaBrandon's Avatar
Hey guys,
Shoot me a PM if you'd like, I'd be glad to discuss some options with you and recommend some parts for your purposes.
SteedaBrandon is offline
Old 05-23-2012, 09:04 PM
2005Redfire6
Will do Brandon, thanks.
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Coil-over/Suspension question
