Replace or Reuse Brake Rotors
Old 06-12-2012, 02:31 PM
acascianelli
acascianelli's Avatar
Default Replace or Reuse Brake Rotors
With 58,000 miles on the clock I finally need to change my brake pads. I'm having a hard time deciding whether or not to buy new brake rotors, or reuse the existing ones.
If I buy new ones, I'll be getting a set of Powerslot slotted rotors from Brenspeed.
acascianelli is offline
Old 06-12-2012, 02:34 PM
Derf00
Gentleman's Relish
Derf00's Avatar
fronts or rears?
Derf00 is offline
Old 06-12-2012, 02:53 PM
acascianelli
My rears are the ones causing a problem right now, but I was going to change them all around.
B.Richards
B.Richards's Avatar
Get them turned there is nothing wrong with them!!!!
B.Richards is offline
Old 06-12-2012, 03:04 PM
acascianelli
I know that's the financially responsible thing for me to do, and I know that slotted rotors won't really do me any good; but I'm still considering the "upgrade" anyway.
Old 06-13-2012, 07:55 AM
Argonaut
Argonaut's Avatar
Sounds like you already know that slotted rotors won't change the brake performance. As far as looks go however, to me there is no contest - if you got the extra $ get the powerslots.
Argonaut is offline
Old 06-13-2012, 10:52 AM
Norm Peterson
Norm Peterson's Avatar
It's only financially responsible if after cutting you still have more than minimum rotor thickness remaining.
Never mind that cutting the rotors removes some metal mass and essentially throws away a little heat capacity and fade resistance. This isn't going to be a simple "pass ==> fail" kind of thing unless you're extremely hard on your brakes and need to have a lot cut. But it is something to consider.
I've had really good experiences with the grooved ATE "Premium One" rotors on two different cars. The grooves may even be reducing the tendency for the rotors to get scored by helping to keep debris from getting trapped between the pads and the rotor faces.
Norm
Norm Peterson is offline
Old 06-20-2012, 09:13 AM
acascianelli
I took my rotors to O'Reily to try to have them turned, they told me that their right on the limit of being able to turn. One of them has some pretty deep grooves and they said that they're fairly certain that it'll be well below the limit after then turn it.
So now I'm still stuck on whether I want to spend the $600+ to replace all 4 rotors and pads with Powerslot slotted rotors and ceramic pads, or just replace the rear rotors and pads.
The Front pads and rotors look to be in great condition still, no rust ridge and the pads still have a little over 1/4 inch left on them.
I'm still baffled that the rear pads wore out so much faster than the front.
Old 06-21-2012, 07:42 AM
Norm Peterson
I'm betting that you leave the traction control on a lot of the time and drive hard enough to activate it.
Norm
Old 06-21-2012, 11:26 AM
DPE
DPE's Avatar
Get some take-off OEM rear rotors from Roush off of ebay for $40 shipped, and then pick out an OEM-level pad you like and be done with it (might see if Roush has take-off OEM rear pads too). In theory you could do that for $100, and as a guy who has spent WAY too much money on useless car parts in my misspent (pun intended) youth, then you could allocate that $500 you save toward something else for the car. Or just keep it in your pocket. Not suggesting Powerslots and ceramics would be useless, but that it's essentially just a very small appearance upgrade which doesn't seem worth $500 to me. I have also become poor and cheap in my old age, so take it with that grain of salt. . .
DPE is offline
Quick Reply: Replace or Reuse Brake Rotors
