LCA relocation vs Adj UCA
I’ve done the following modifications to rear suspension. Lower rear 1.5 inch, new sway bar, and BMR LCA fixed length. I was going to add a adjustable UCA but I’ve read a number of horror stories about the installation. I was thinking of just installing a LCA relocation bracket. By lower the arm and changing the angle you effectively shorten the arm. With a little creative math I should be able to figure what angle to set the LCA and correct the pinion angle. Any comments or opinions why this would or wouldn’t work.
LCA relocation brackets will probably increase your roll oversteer which could make hard cornering an exciting experience (not in a good way unless you like drifting). IMHO you should consider selling the fixed length LCA and use the money toward an adjustable LCA and set the pinion angle that way.
Never mind that with relo brackets there is some chance that due to fabrication and/or installation errors you will still need at least one LCA to be adjustable in order to square the axle in the chassis (zero thrust angle on an alignment printout sheet). For this reason I would never consider doing only the relo brackets and calling it done. Even if I was willing to try just the brackets, it would be with planning from the get-go to get the adjustable LCAs if the axle ended up the least bit out of square.
Norm
S197 Suspension NEW RELEASED KITS
For all you S197 Lovers... Im here for you Finally after soo many years of people asking me to make street version!
We've built the Formula Drift Angle used on Vaughn Gittin Jr and JTP(Justin Pawlak) Mustangs...
NEW RELEASE!
http://www.ebay.com/itm/151406533374...84.m1555.l2649
NEW RELEASE!
