Shelby 2008 suspension part better then my 2013 gt suspension?
Old 12-25-2013, 02:46 PM
mighted1987
mighted1987's Avatar
Default Shelby 2008 suspension part better then my 2013 gt suspension?
I can have 2x lower control arm ford racing oem shelby lca with the stock uca all oem stuff, i know the lower control arm are an improvement, but what about the uca? Is it the same part used on gt?
I can have everything for 140$ just wondering if there is any difference,
I can also have a 2013 shelby front sway bar but yet again i dont know
if it is the same part from the 5.0
God my english is horrible.
mighted1987 is offline
Old 12-25-2013, 03:43 PM
Rocket Ray
Rocket Ray's Avatar
Your English is probably better than most people's French that are on here, nes pas? Unfortunately I don't know the answer to your question. I believe the lower control arms are the most important ones if you are looking for better grip and launch control. The stock UCA is not adjustable, so if you are putting lowering springs on the back you may want an adjustable one. You should be able to search the web and find out if the Shelby sway bar is different from the one on the GT ( I would guess that it is).
Keep this topic near the top, someone will read this who will be able to give you some good advice. You might want to copy this topic to the handling forum also.
Rocket Ray is offline
Old 12-25-2013, 04:03 PM
outceltj
outceltj's Avatar
post in the handling section and sam strano will probably be able to answer that
outceltj is offline
Old 12-25-2013, 04:06 PM
outceltj
outceltj's Avatar
plus the many other suspension guru's there
outceltj is offline
Old 12-25-2013, 04:29 PM
Moderator
JimC's Avatar
Moved your thread, it's a little better in this section.
Si vous s'il vous plait (wow, my high school french is really rusty, not even sure if I spelled it correctly now and can't find the grammar marks on this keyboard)
JimC is offline
Old 12-26-2013, 08:49 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
The Shelby suspension is not a significant upgrade compared to most of the aftermarket manufacturers' suspension components.
UPR Products control arms are much better quality and performance than the OEM Shelby parts.
UPRSharad is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
RWHEELS
09-05-2015 03:42 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Shelby 2008 suspension part better then my 2013 gt suspension?
