LCA Relocation Brackets for ESP
After reading the SCCA rule book, it appears that aftermarket LCA's aren't allowed in STU or ESP. For STU, it also says that they can't be relocated, but it doesn't specifically say that for ESP. So are relocation brackets allowed in ESP?
Also, if I install relocation brackets, I suppose that will throw off my pinion angle and I'll need a adjustable upper control arm? Will the relocation brackets be as effective with stock LCA's?
I suggest emailing the SCCA at http://crbscca.com/ for clarification.
Typically, if the rules in a section (such as "Street Prepared") do not specifically allow a particular modification then it is not permitted in that category.
However, it is legal in *SP to utilize offset bushings which can perhaps accomplish what you're trying to do in a class-legal manner (if to a somewhat limited extent).
Norm
Norm
If you install them you are going to be in Street Mod. And no, it does not change the pinion angle (unless they are installed wrong). LCA brackets change geometry, you don't need different LCA's to make them do what they do. But that said, I doubt you need to do what they do.
UCA changes are legal, and I start there on the cars I setup. Between lowering and fixing the bushing issues up there (which is more responsible for axle wind up than lowers anyway), we generally have no need to worry about lowers after that.
Thanks for the replys. Definitely don't want to go to Street Mod. Are the brackets and LCA's more for high horsepower applications?
Would upper control arms with good polyurethane bushings be a good upgrade for an STU car. The car is an 05 GT with Eibach pro-kit springs, shocks, struts, sway bars, and camber plates.
Autocrossing can be quite violent on the suspension, tossing the car around those cones. Personally, I can absolutely feel the improvement in stability from upgraded control arms. But keep in mind, I'm not an FS racer, so I'm not limited to the factory garbage.
With regard to poly vs spherical bushings, the sphericals work better, but they make more NVH, so it's up to you to determine what you're willing to deal with. If it was a racecar, the sphericals would be the automatic choice.
Norm
As for the upper arm. I do uppers all the time. I have a preferred setup which replaces everything from the bracket, through the arm, to the bushing that is in the diff housing (that gets replaces with a spherical bearing). Not only is it all legal, but it's IMHO better for dealing with bumps than stiff LCA's and I find much better for wheelhop as it's the upper arm that is responsible for controlling the rotation of the axle. Not saying lowers do nothing at all in that way, but again they aren't legal and it's kind of moot here for that reason.
One thing I work really hard at it staying on point with the mods. Not only mods what will make the car better, but also what is ok for those of us who do autocross with SCCA to stay legal.
