Camaro's 1LE similar wheel & tire set up for our GT's?
Old 04-13-2014, 05:10 PM
M3hunter
M3hunter's Avatar
Question Camaro's 1LE similar wheel & tire set up for our GT's?
Hey Guys,
Do you think we can imitate Camaro's 1LE tire wheel set up, maybe this will improve our GT handling: with 285/35R19 tires mounted in 19x10 front wheels and 19x11 rear tires?
M3hunter is offline
Old 04-13-2014, 06:25 PM
Stang-aholic
Stang-aholic's Avatar
I know that its possible to run really wide tires on 11s (305s) out back, but im pretty sure you will run into rubbing issues running 285s in the front. i know some people have done it, I would stick to 275s just to be safe.
Stang-aholic is offline
Old 04-13-2014, 09:54 PM
jackal119
jackal119's Avatar
The 1LE Camaro is for the most part just a set of 20x10 wheels with a 285 tire, Goodyear G2 tires if I recall. You should be able to hold your own with just the bembo package, two of the weak points other then the dampers in the Mustang are its brakes and crappy tire choices for the OEM wheels. But BFgoodrich will have the Rival out in the 255/40-19 and 285/35-19 in about 4 weeks. The 1LE package is a well done package within its oem setup and the ride is not to bad at all. Having only met one other owner out there with one its a rare sight to even see a new gen Camaro at the track. The Camaro's brakes are the only real strength I seen.
jackal119 is offline
Old 04-13-2014, 09:58 PM
Andy13186
Andy13186's Avatar
I have 275 40 19s and 315 35 20s
The 315s rubbed sheetmetal fender with steeda sport springs, they are ok with the stock springs but stick out a bit farther than the fenders. The fronts have had no issues and seem to fit fine even with steeda sport springs. I am pretty sure this is as big as i would want to go though.
Andy13186 is offline
Old 04-14-2014, 05:26 AM
tigercrazy718
tigercrazy718's Avatar
You can run 285's up front with the correct offset on an 18x10 wheel. Source: I did it two weeks ago with my track tires.
tigercrazy718 is offline
Old 04-14-2014, 01:01 PM
jRaskell
jRaskell's Avatar
I'm running 285/35/18s on 18x10 wheels on all 4 corners as well, and with no rubbing at all. That setup is an inch less diameter than a 19 inch setup though, so it isn't a perfect comparison.
I would always go with a completely square setup as well, to allow for some limited tire rotation. I run directional tires, so I can't do any sort of cross-rotation without remounting the tires, but I can at least rotate front-back, and it does help with the life of the tires.
jRaskell is offline
Old 04-14-2014, 01:14 PM
darksky1984
darksky1984's Avatar
You can run 295s with a 42 offset on 18x10 rims and probably still not rub. But to be safe I'd run a 3mm spacer up front.
darksky1984 is offline
Old 04-14-2014, 07:29 PM
M3hunter
M3hunter's Avatar
I will like to stick with 19"s. I think they will fill the holes better than 18"'s.
M3hunter is offline
Old 04-16-2014, 09:56 AM
Norm Peterson
Norm Peterson's Avatar
Running wheels wider than 18x10" with 285/35's or even 295/35's all around is physically possible. There will likely be a compromise or two involved - offset gets pretty critical else the wheels may stick out a little, you may have to run camber that's a bit more negative than anywhere in the OE range, and you may not be able to swap the wheels front to rear due to different offsets needed.
One of the 1LE wheel widths and that car's tire section (285/35) is my "design bogey" as well.
Norm
Norm Peterson is offline
Old 04-16-2014, 10:55 PM
M3hunter
M3hunter's Avatar
Norm and what about 19"'s on that size?
M3hunter is offline
Quick Reply: Camaro's 1LE similar wheel & tire set up for our GT's?
