Lowering your 05/06 Mustang GT
Old 03-01-2013, 10:53 AM
  #511
audioAl
audioAl's Avatar
Dang Norm, I could not tell how to clock the new springs, it handles great in the twisty's.
Yes, the bang was after the install and torque of all bolts. I need to do another burnout
an see if it Bangs again I guess? Thanks for your reply,Alan in sunny Seadrift,Tx.
audioAl is offline
Old 08-27-2013, 08:22 PM
  #512
lilredmiranda7
lilredmiranda7's Avatar
Thread helped alot
lilredmiranda7 is offline
Old 11-12-2013, 10:44 AM
  #513
JasonIsAGeek
JasonIsAGeek's Avatar
I already posted this in my own recent thread in this section, but thought I should put it up here so I could get some more eyes on it.
From my other thread:
So of course after considering suspension stuff I want to do some things I've thought of since buying the car new over 8 years ago. Namely lowering and handling upgrades. I would be doing all the work myself. Here's a couple of options I'm considering.
Both would include either the SR (AM brand) or FRPP front LCA and new front outer tie rods or the bumpsteer kit.
Option 1
-SR Performance springs (1.5 " drop) since they're on sale right now at AM for $99
-Koni Str.T struts/shocks or possibly Strange adjustable (same price as Koni's)
-J&M or QA1 caster/camber plates (although maybe I could just get away with using camber bolts and the Ford racing strut mount upgrade?)
Option 2
-Keep it simple and go with something like the Eibach Pro-System-Plus Kit (1.3" front, 1.5" rear drop), which would probably save me a little bit of money in addition to adding a front and rear sway bar
Also aware that I should probably do an adjustable rear panhard bar, although some people seem to think it's not necessary. Any tips/advice? Am I forgetting anything you guys would consider necessary? Relocation brackets? Thanks for the help.
JasonIsAGeek is offline
Old 11-12-2013, 12:45 PM
  #514
JasonIsAGeek
After some further reading in this thread, it looks like the Eibach pros with Tokico adjustables are a popular combination. Any thoughts on how the Tokicos compare to the Strange adjustables?
Old 02-28-2014, 09:30 PM
  #515
02GTowner
02GTowner's Avatar
I did Roush springs all around, koni str.t shocks and struts, j&m adjustable panhard bar, steeds hd strut mounts/ camber plates with the ford k member brace and frpp strut tower brace. Handles great and is low enough to eliminate some of the 4x4 stance but doesn't bottom out or scrape on driveways or bumps.
02GTowner is offline
Old 10-11-2014, 06:56 PM
  #516
UrS4
UrS4's Avatar
Thought I'd post a recent pick with current set up
UrS4 is offline
Old 10-12-2014, 07:21 AM
  #517
audioAl
audioAl's Avatar
Default 2014 DIB 3.7 w/ sport shift "Blue Cyclone"
Nice stance, my new pony needs help, waiting on funds.
Attached Thumbnails  Lowering your 05/06 Mustang GT-tn_yokohama-and-shelby-s-005.jpg
audioAl is offline
Old 09-07-2015, 10:37 AM
  #518
jetmek
jetmek's Avatar
Originally Posted by mustangvert555
My overall opinion about the drop on the new Mustangs is simple... Don't be tempted to put stupid sized wheels on the car just because the new mustang wheel wells will take them. First of all, it defeats the purpose of lowering the car because huge 20+ sized wheels give the car an off-roading appearance rather than the mean stance that the car should have. Second, it just looks stupid... This is a good drop right here...
LEAVE YOUR MARK IN NJ AND HELP OUT A MUSTANG PROJECT AT THE SAME TIME!!
CHECK THIS OUT!!!
In case you are still on this thread, I wanted to correct you on size of tires. A 275/35/20 tire is only.3" taller than the stock 18" tires for this car and a 275/40/20 (which is the Saleen choice) is only .4" taller. Still less than a half inch taller tire. They fit wonderfully and I get HUGE compliments on my car. They may not look right to you but it does not defeat any purpose as it only brings the car up off the ground .2".
jetmek is offline
Old 04-06-2017, 01:36 PM
  #519
Whiteline
Former Sponsor
Whiteline's Avatar
Whiteline is currently running a 25% off Lowering Spring Sale:
S197 Lowering Springs
Front Lowering Height: 35mm / 1.38 inches
Rear Lowering Height: 45mm / 1.77 inches
Front Spring Rate: 194 in/lbs
Rear Spring Rate: 274 in/lbs
S197 Lowered with Whiteline Lowering Springs
Whiteline is offline
Old 09-12-2019, 06:19 AM
  #520
Norm Peterson
Norm Peterson's Avatar
I finally did get around to lowering my '08 - probably a couple of years ago. But not out of any desire for a lower ride. I was datalogging in excess of 1.25g in the corners on road courses while still on the OE GT springs. IOW, you don't NEED to lower your car for cornering capability up around double what most people will ever use on the street.
I went with BMR's Handling Springs for a GT500 (slightly stiffer than their Handling springs for a 'regular GT') because nose dive/tail rise under hard braking at HPDE track days was beginning to bother me, and the lowering was simply the unavoidable consequence. Being lighter up front than a GT500, my GT only dropped about half an inch, and I'm completely fine with that. Never wanted any more than about 3/4" or 20mm anyway. Out back was a different story, as that end dropped about an inch. So I worked up a way to shim about 3/8" of that away to put the rear lowering at about 5/8". I'm probably going to take another quarter of an inch out of the rear lowering to end up closer to 3/8" drop.
Norm
Norm Peterson is offline
Quick Reply: Lowering your 05/06 Mustang GT
