S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
should i buy 2007 shebly gt500
Old 03-11-2010, 11:01 AM
ericmuscle
ericmuscle's Avatar
Question should i buy 2007 shebly gt500
thinking about buying a used 2007 shelby gt500 in 6months to a year from now and im just curious if i should or shouldnt, considering all the things ive read about the clutch problems and dealers not wanting to fix the problem when you bring your car in cause it wont shift. i know there are tsb's for this issue, but are the dealerships fixing this issue if you bring your car in with the problems. ill probably purchase one from my local dealer or from carmax, which car max offers a extended warranty on their cars if you decide to purchase it, which i would. should i buy one or would i be buying a potential problem car. car would be my daily driver and i dont abuse my car at all, but it would see boost from time to time. thanks for any input.
ericmuscle is offline
Old 03-11-2010, 02:35 PM
07 naja
07 naja's Avatar
Buy one. The potenial problems are no greater with the 07 and early 08 cars than any other car. Make sure that the TSB has been done or knock off about $2500 to $3000 from thier best price to have it done.You might want to check w/ your local Ford dealer or performance shop to verify the price. That price was what i paid to have mine done last fall.
There is a bunch of info out there on the TSB.
Vic
07 naja is offline
Old 03-11-2010, 02:45 PM
05 Mustang
05 Mustang's Avatar
I wouldn't NOT buy one just because of the known "clutch issue".
I bought mine knowing there was an issue for all GT500's built before 01-Sept-09, but if something happens, then I'll take it to my local Ford dealer and have them take care of it for me.
05 Mustang is offline
Old 03-12-2010, 01:36 AM
Snakebite64
Snakebite64's Avatar
. If there is a tsb but I drive my car very little does the tsb go into the future?
Snakebite64 is offline
Old 03-12-2010, 11:01 AM
white_lightning
white_lightning's Avatar
A TSB is only valid within the original warranty parameters, it does not extend any warranty. In your case 5 years or 100,000kms is the coverage
And to the OP yes you should buy a GT500, because they are awesome.
white_lightning is offline
Old 03-12-2010, 02:34 PM
deekum1627
deekum1627's Avatar
buy it def buy it. i agree with 05 mustang
deekum1627 is offline
Old 03-12-2010, 10:59 PM
moburto07GT
moburto07GT's Avatar
^^^I 100% agree with this. My car has almost 46k on the original clutch and flywheel with out any of the problems other than hiss on take off, (normal for a twin disc clutch, at least from my experience). And when and if it has any issues i will just replace it with a better aftermarket setup anyways, because once you have had the car for a while you will start getting use to the power and start wanting more. So might as well just replace it with something that will hold almost anything i can throw at it.
moburto07GT is offline
Old 03-13-2010, 12:47 AM
Snakebite64
Thanks Nick
Old 03-13-2010, 09:51 AM
cheftjpeck
cheftjpeck's Avatar
I agree with Cameron (05) buy it... I had the tsb performed on my 08 pretty easily ... Check to see if it was done before buying and if not then use it in your negotiation.... As far as 5 year 100,000 mile warranty on the gt500? Unless your dealer offers you an extended warranty then standard is 3 yr 36,000 miles 5yr 60,000 drivetrain but read the fineprint on the drivetrain... Does not cover allot of areas
just an FYI
cheftjpeck is offline
Old 03-19-2010, 11:54 AM
BCisme
BCisme's Avatar
Originally Posted by moburto07GT
^^^I 100% agree with this. My car has almost 46k on the original clutch and flywheel with out any of the problems other than hiss on take off, it.
I always tell passengers they hiss because that's just what cobras/shelbys do.
and yes buy one. now.
BCisme is offline
Quick Reply: should i buy 2007 shebly gt500
