New to the Forum
Old 10-25-2016, 01:17 AM
Sean Maloney
Sean Maloney's Avatar
Default New to the Forum
Hey everyone i just got me a brand new 2016 Mustang GT its awesome. but i can't wait to start doing things to it. it needs exhaust!! any suggestion? and if i out exhaust on the car does it void the warranty? I was thinking of the MBRP.
what does void the warranty? if anyone knows
I'm looking to get an intake, exhaust and then get it tuned, and get some lowering springs on it. i can't believe how smooth it rides, i just hope there are some springs out there that ride similar to the way it does now.. any suggestions on springs also?
thanks everyone.
Sean Maloney is offline
Old 10-25-2016, 08:37 AM
1 Alibi 2
1 Alibi 2's Avatar
Welcome to the site, congrats & good luck with the new ride.
Post some pics when you get a chance.
Have an end goal for the car before you spend any money, that way you only buy stuff once.
It's easy to throw $$$$ at these cars, have a budget.
Read, it costs nothing to research, & can save you money in the long run. Someone has already done what you want to do.
If you are serious about performance upgrades, one of the best in the business is in Freehold, N.J.
( they aren't cheap & you'll wait for an appointment )
www.teamjdm.com
1 Alibi 2 is offline
Old 10-25-2016, 09:36 AM
movielover40
movielover40's Avatar
Welcome aboard and congrats on new Mustang.
I would put some miles on it first before modifying it.
movielover40 is offline
Old 10-25-2016, 02:52 PM
proeagles
proeagles's Avatar
Congrats on the new car. I always recommend staying away from CAI and new tunes. Read the forum, tons of misgivings and problems and the most likely to void your warranty depending on the dealer. I went with the Ford Racing (Borla) street exhaust with X-pipe, plenty loud under throttle and startup and yet reasonably quiet cruising. Eibach make a good spring kit only to lower the vehicle about 1" which is all it needs and it will ride pretty much the same as it does now. You didn't say whether you got the performance track pack or not. That would dictate more of what you should do.
proeagles is offline
Old 10-25-2016, 03:45 PM
Airfuel
Airfuel's Avatar
thanks everyone.
Performance pack? I'm also looking for smooth ride and am considering just premium, no PP.
Airfuel is offline
Old 10-25-2016, 06:22 PM
Moderator
JimC's Avatar
thanks everyone.
"Voiding the warranty" is really quite simple. Ford warranties the car that Ford built. When you make a change it is no longer the car that Ford built. If that change can be A cause of your problem then Ford can deny warranty coverage for that repair.
If you change the mufflers and your engine blows up or transmission goes out, not likely that the mufflers are A cause of the problem. But if you put a tune on the car, changing the factory parameters, and a piston exits the block, then Ford will say that your tune contributed to or caused that failure and they have no way of knowing if but for your tune the engine would have been fine. Yes, Magnuson-Moss says that Ford has to prove your modification was the cause of the problem and you will see people touting that as your protection. Some will also say you need a better dealer, but warranty coverage isn't always the dealer service department call; they have to get approval from Ford in order to get paid for the work. Dealers won't turn away warranty work as some suggest because it is a sure payment; but they also won't try to cheat the system because then Ford will fly-speck every warranty claim and they will lose business or be told they can't even do warranty work anymore.
Ford will have sent out a field engineer to inspect the engine or part that failed. The Ford field engineer will write his report blaming the tune for a blown engine. Warranty coverage will be denied and you have to sue to get the warranty coverage. Which means find your own engineer to test and testify how your modification didn't cause the problem - meanwhile, Ford has a whole division full of them to fight yours, which you are paying for out of your pocket. You also have the cost of the litigation both in dollars and time, and Ford has more time and deeper pockets for that fight (and based upon the amount at issue an attorney isn't going to take the case on a contingency). So you will have to spend a lot of dollars and time to get warranty coverage once it is denied.
Modifications don't void your warranty though. If you add a tune and your radio craps out, then you will still have coverage for that no problem. The "voiding" is really denial of warranty coverage for a specific incident.
Note that I said A cause of the failure. Ford doesn't have to prove or say that it is the SOLE cause, only a proximate cause.
JimC is offline
Old 10-29-2016, 10:07 AM
audioAl
audioAl's Avatar
Default Coyote Red
Welcome to the forums, I did the SVE resonator delete X-pipe & Airaid Tube. Break-in is essential before too many mods. And a UPR catch can is needed as well.
audioAl is offline
Old 10-29-2016, 12:24 PM
Mach2
Mach2's Avatar
Exhaust wise, my first recommendation would to leave the stock GT mufflers and install a X-Pipe replacing the stock resonator. If that doesn't pull your trigger, leave the stock resonator and replace the stock GT mufflers with a Legato axle back system. That's what I have and love it. Noticeable at idle, nice sound accelerating and great sound at WOT. The mufflers look to be Flowmaster 40's.
https://legatoperformance.com/collec...-gt-v8-exhaust
Mach2 is offline
