tb and plenum
RE: tb and plenum
The 75mm TB will bolt right up to the inlet pipe of the supercharger. Just remove the stock 65mm (?) and put up the new one...just adjust the TPS correctly and let the car relearn idle. You should be good to go.
The 90mm LMAF works just fine.
ORIGINAL: josh00saleen
I have a 75 mm bbk tb and I was wondering if I needed to get a new plenum as well. Have a 2000 S/C saleen. Also do the lightening 90 mm maf work ok or another brand recommended. thanks Josh
Gary Ugarek
08-26-2015 08:41 AM
