Extremely Clean Blown Mystic Cobra BUILT EVERYTHING...20K
96 Mystic Cobra with just about everything you can think on it. Body and chassis have 88k on it, the rest has 1500 at the max. Since being done the car has only been driven to the Speed Shop and backand to a few local meets and one car show. New Built 4.6 with an authentic, new teksid block, manley h beam rods, JE 9.2:1 pistons, forged steel crank, top of the line bearings, gaskets ect. New titanium valve springs, and retainers. Vortech S-trim with brand new aftercooler, saleen heat exchanger. New built 3550 trans with new clutch and flywheel, aluminum drive shaft, custom built 8.8 from DTS with 33 spline axles, auburn pro limited slip diff, 3.55 gear, welded axle tubes and extended studs. UPR pro series upper and lower rear control arms, welded subframe connectors, tokico 5 way adjustable drag shocks and struts, pro series Chrome moly tubular front suspension with coilovers and caster camber plates. Also custom fitted cage with some trick stuff, 5 point corbaeau harnesses. 03 cobra seats, most interior platic is also painted Mystic. Long tube BBK's with off road H and and Magnaflow Catback. Car runs and drive great, is dead straight and idles near stock thanks to stock cams. It makes over 600 Hp on pump gas and could make alot more on race gas. 13psi pulley is on for street duty but the car has a dyno tune of 530 RWHP right now, although a 18psi can and has been used, but not on the new motor. The tune is very conservative, with the A/f being around 10.5:1 and using minimal timming. THIS CAR IS AN ABSOLUTE BLAST TO DRIVE AND ATTRACTS ATTENTION EVERYWHERE IT GOES. It is a great true street car, it can definatly go 10's since it went low 11's with the old combo and way to much gear, has A/C, Power steering, full interior, stereo, and all the cobra power options still and is a rocket. The car even gets good gas mileage as long as you are nice on the pedal.OVER 35K INVESTED IN THIS MACHINE.
CONSIDERING TRADES AND OFFERS AT THIS TIME.
RE: Blown Mystic Cobra For Sale Central FL
ORIGINAL: live4motocross11
how much r u asking
how much r u asking
+1 , where in Fla are you ?
pics and a roundabout price if you would. ard404@jwu.edu.
thanks, ard404
thanks, ard404
ard404 your email keep rejecting my messages please give me another email or call me 407-758-1304
Can you send pictures to Nattybrew91@aol.com Also, I have a 1994 Mustang GT with a 347, Tremec, all that good stuff too if your willing to make a trade. Let me know in the email.
