$1500 96-04GT Supercharger kit "how its done"
Old 06-03-2007, 10:58 PM
Frostbitten
Frostbitten's Avatar
Default $1500 96-04GT Supercharger kit (updated for more cars!)
Many many people have been asking me how I got my supercharger kit for less than $1500. Well, this is how its done....
All I really did was search through http://www.superchargersonline.com and you can find prices for different makes and models. All of this is completely legal lol. I do not work for them but they just have good service and they helped me build my kit. Basically this is a how to piece together your own supercharger kit, so that it comes out alot cheaper than buying an off the shelf kit lol
This is a list of parts youll need to buy:
1. Bracket Assembly
2. Discharge Assembly
3. Air Intake Assembly
4. Oil feed
5. Oil drain
that is just to put together the kit. I have been told that the 96-98 cobras need an addition coolant crossover tube that retails for around $400 from vortech. You will also need to upgrade your fuel injectors and the fuel pump also to supply enough fuel for the supercharger.
1. BRACKET ASSEMBLY
00-04 GT http://www.superchargersonline.com/i...oducts_id=5398 $279
96-98 GT http://www.superchargersonline.com/i...oducts_id=5309 $229
99 GT http://www.superchargersonline.com/i...oducts_id=5400 $274
86-93 5.0 http://www.superchargersonline.com/i...oducts_id=5175 $399
94-03 V6 http://www.superchargersonline.com/p...er=V4FF111-021 $279 *was removed from website*
03/04 MACH 1 http://www.superchargersonline.com/i...oducts_id=7357 $339
94/95 5.0 http://www.superchargersonline.com/i...oducts_id=5267 $359
96-98 COBRA http://www.superchargersonline.com/i...oducts_id=5353 $274
99 COBRA http://www.superchargersonline.com/p...er=V4FR111-021 $289
01 COBRA http://www.superchargersonline.com/p...er=V4FR111-031 $329
05-09 GT http://www.superchargersonline.com/p...er=V4FU111-044 $379
2. DISCHARGE ASSEMBLY
96-04 GT http://www.superchargersonline.com/i...oducts_id=5311 $197
86-93 5.0 SCi Trim (plastic) http://www.superchargersonline.com/i...oducts_id=5186 $88
86-93 5.0 Si Trim (satin) http://www.superchargersonline.com/i...oducts_id=5187 $209
94-03 V6 http://www.superchargersonline.com/p...er=V4FF112-020 $214
03/04 MACH 1 http://www.superchargersonline.com/p...er=V4FR112-020 $299
94/95 5.0 http://www.superchargersonline.com/i...oducts_id=5270 $135
96-98 COBRA http://www.superchargersonline.com/i...oducts_id=5356 $299
99/01 COBRA http://www.superchargersonline.com/i...oducts_id=5495 $299
05-10 http://www.superchargersonline.com/i...oducts_id=5531 $179
03/04 MACH1 http://www.superchargersonline.com/i...oducts_id=7459 $299
2001 BULLITT http://www.superchargersonline.com/i...oducts_id=5403 $279
3. AIR INTAKE ASSEMBLY
96-04 GT http://www.superchargersonline.com/i...oducts_id=5310 $228
96-04 GT **AFTERCOOLED** http://www.superchargersonline.com/i...oducts_id=5402 $235
86-93 5.0 *Si Trim* http://www.superchargersonline.com/i...oducts_id=5185 $159
86-93 5.0 *SCi Trim* http://www.superchargersonline.com/i...oducts_id=5184 $159
94-04 V6 http://www.superchargersonline.com/p...er=V4FF112-010 $204 *removed from website*
03/04 MACH 1 w/mass air http://www.superchargersonline.com/i...oducts_id=5494 $522
03/04 MACH1 **Vortech Shaker Kit**
http://www.superchargersonline.com/i...oducts_id=5497 $549
94/95 5.0 http://www.superchargersonline.com/i...oducts_id=5268 $219
96-98 COBRA http://www.superchargersonline.com/i...oducts_id=5354 $254
99/01 COBRA w/o mass air http://www.superchargersonline.com/i...oducts_id=5493 $269
99/01 COBRA w/ mass air http://www.superchargersonline.com/i...oducts_id=5492 $399
05-10 GT http://www.superchargersonline.com/i...oducts_id=5530 $289
4. OIL FEED ASSEMBLY
96-04 GT and 96-01 COBRA http://www.superchargersonline.com/i...oducts_id=5313 $23
96-04 and 96-01 COBRA *upgraded stainless steel* http://www.superchargersonline.com/i...oducts_id=6021 $82
94/95 5.0 http://www.superchargersonline.com/i...oducts_id=5276 $29
86-93 5.0 http://www.superchargersonline.com/i...oducts_id=5202 $69
05-10 GT http://www.superchargersonline.com/i...oducts_id=5537 $38
5. OIL DRAIN ASSEMBLY
96-04 GT, MACH 1, and COBRA http://www.superchargersonline.com/i...oducts_id=5314 $23
94/95 5.0 http://www.superchargersonline.com/i...oducts_id=5277 $27
86-93 5.0 http://www.superchargersonline.com/p...er=V4FA130-036 $34
05-10 GT http://www.superchargersonline.com/i...oducts_id=5538 $15
***MISC. PARTS*** (may be necessary)
96-98 COBRA Air Pump Relocation Assembly
http://www.superchargersonline.com/i...oducts_id=5351 $49
COBRA Vortech Mounting Bracket Plaque
http://www.superchargersonline.com/i...oducts_id=7525 $56
01-04 GT PCV Bypass Assembly
http://www.superchargersonline.com/i...oducts_id=5408 $22
86-93 5.0 PCV Bypass Assembly
http://www.superchargersonline.com/i...oducts_id=5204 $29
1. Vortech Bracket Assembly: $289
2. Vortech Discharge Assembly: $199
3. Vortech Air Intake Assembly: $215
4. Vortech Oil Feed Assembly: $22
5. Vortech Oil Drain Assembly: $23
Total: $748 before tax/shipping
That is cost for EVERY single item you need to put a Vortech S, SQ, or T trim on your 2000-2004 Mustang GT. For other models just add up the prices listed. Only thing left to buy is the head unit. They are fairly easy to find if you search Ebay, SVTperformance.com, or Corral.net . A used S-trim sells between $400-800 depending on assumed mileage and condition. I bought mine for $700 with discharge pipe and intake. If you want a new head unit they cost $1849 for a brand new satin V-1 s-trim. A used head unit WILL be alot cheaper and perform just as well. Even if the unit needs a rebuild, the cost is about $350 from vortech or you can find some performance shops that can do it for around $100. Mine was in great condition when I picked it up from a guy on Ebay. Even bieng a 6 year old head unit it had no shaft play and seems to be in perfect condition.
If you find a head unit for $600, add the cost of the hardware ($748) and this comes out to $1348 for a COMPLETE vortech s-trim setup every part new but the head unit and fuel injectors. Even if you paid say $800 it would just come out to $1548 before tax and shipping. All setups will need to be tuned on a dyno
Install takes a full days work to get it done right. Anyone with general knowledge of removing and installing bolts on the front of the timing cover, removing the belt, using a pipe tap, and swapping non-pressed pullies can perform this install.
Heres the install manual for a GT: http://www.google.com/url?sa=t&rct=j...hCuRpXc5aHxPYg
BTW my ebay head unit is still in perfect condition after 20,000 miles of street/track time.
Non-intercooled setups will make around 350-370whp on 8psi. Intercooled setups can make 370-390whp on 8psi and over 400whp on 10psi with supporting mods on a 99-04 GT.[8D]
Frostbitten is offline
Old 06-03-2007, 11:44 PM
luckythirteen13
luckythirteen13's Avatar
Default RE: $1500 96-04GT Supercharger kit "how its done"
impressive
luckythirteen13 is offline
Old 06-04-2007, 02:19 AM
r.barn
r.barn's Avatar
www.treadstoneperformance.com has some damn nice air to air intercoolers
for about $400 also.
r.barn is offline
Old 06-04-2007, 05:35 PM
610sWolf
610sWolf's Avatar
Nice write up man, I'm strapped for cash right (two sons, finding new place to live),but really want the performance boost to the car, I'm going to look into this.
610sWolf is offline
Old 06-05-2007, 08:53 PM
thbdjacks
thbdjacks's Avatar
you got any pics to post of your setup installed?
thbdjacks is offline
Old 06-05-2007, 09:05 PM
Frostbitten
ORIGINAL: thbdjacks
Old 06-05-2007, 09:09 PM
Frostbitten
another
[IMG]local://upfiles/44338/026A502524444364B713792717B2ACAD.jpg[/IMG]
Old 06-06-2007, 02:28 AM
jst854
jst854's Avatar
so basically this is everything i would need besides the head unit and supporting mods? http://www.superchargersonline.com/p...er=V3FH218-010
jst854 is offline
Old 06-07-2007, 10:26 PM
Frostbitten
ORIGINAL: jst854
Yes, that does include everything, but you should not buy the complete "mounting kit" because it costs ALOT more than if you were to buy the parts seperately through the "accessories" part of the website. That kit is $1700 where you could get all the same parts for $750 through the accessories section. Its crazy why they would charge that much simply because its a "kit".
Old 06-08-2007, 12:18 PM
performance_stangs97
performance_stangs97's Avatar
Thanks alot for posting this thread, I think this is the way Im going to go
performance_stangs97 is offline
Quick Reply: $1500 96-04GT Supercharger kit "how its done"
