ac delete bracket?
Old 07-10-2013, 03:21 PM
90foxbdy
90foxbdy's Avatar
Default ac delete bracket?
i just picked up my mustang and trying to figure out how to tension the darn belt. there is a huge bracket from my alternator to the opposite side of the engine but no tensioner. any ideas? is this normal? HELP!
90foxbdy is offline
Old 07-10-2013, 03:33 PM
lol get a picture of it up man so we can see how its set up.
There should be a tensioner either right beside the alt, or under it.
Old 07-10-2013, 03:47 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Yep. Pics please.
UPRSharad is offline
Old 07-10-2013, 07:16 PM
mattdel
mattdel's Avatar
That bracket you speak of is probably the tensioner itself. Is it hex shaped? If so, that's it.
mattdel is offline
Old 07-11-2013, 07:51 AM
90foxbdy
90foxbdy's Avatar
here she is!
90foxbdy is offline
Old 07-11-2013, 07:52 AM
90foxbdy
90foxbdy's Avatar
90foxbdy is offline
Old 07-11-2013, 10:05 AM
Tony71502
Tony71502's Avatar
Doesn't look like you have a tensioner. Is that bracket even adjustable? Doesn't look like it. It's definitely not normal and looks like a "custom" job.
Tony71502 is offline
Old 07-11-2013, 10:29 AM
This is not the correct way to run this.
What they did was take the upper bolt out of the alt, to allow for a smaller belt. Once they put the belt on they basically use a pry bar or something to push the alt back into place putting tension on the belt . Will work for a very short while till the belt starts to stretch.
If you want to do it correctly you need this
http://www.ebay.com/itm/1982-93-MUSTANG-5-0L-BILLET-ALUMINUM-AIR-CONDITIONER-AC-DELETE-ELIMINATOR-PULLEY-/251133482538?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1991%7CModel%3AMustang&hash=item3a78b8d62a&vxp=mtr
and this
http://www.ebay.com/itm/Gates-38121-Belt-Tensioner-Assembly-/261243333677?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1991%7CModel%3AMustang&hash=item3cd350ec2d&vxp=mtr
Old 07-11-2013, 10:41 AM
Tony71502
Tony71502's Avatar
You don't need a pulley for the A/C delete. The delete kit I have(I think I got it from late model resto) uses the same brackets(alum one that bolts to head and steel one that bolts to water pump) as a stock 5.0 without A/C. They move the power steering pump up to where the A/C used to be.
Old 07-11-2013, 10:53 AM
http://www.latemodelrestoration.com/...A-C-Eliminator
This is what you have correct? Both perfectly acceptable and correct way of doing it. Either way you go you need a tensionor
Quick Reply: ac delete bracket?
