Exhaust Choices?
Old 10-20-2013, 06:24 PM
Logan487
Logan487's Avatar
Default Exhaust Choices?
Hello,
We have a 94 that has glass packs on it now but other than that it is stock to my knowledge, my wife loves the way it sounds at idle and while driving but the passenger side is going bad and I was told by a friend that given it has been made into true duals that the exhaust being that open is bad for the engine. Were going to be modding this car quite a bit in the future so I was wondering if anyone could suggest an exhaust setup that would get that throaty base sound she likes while also being better for the engine's performance. Heres what I had in mind, let me know if I should change anything. I was thinking about removing 2 of the 4 cats but I was told again by the same friend this would be bad for the car but given this same friend has steered us wrong several times now I figured id ask the experts on here. Heres what I had in mind, if anyone knows of a brand let me know but I was looking at a long tube set Id read about online that was the 'optimum length' according to the page I was on. We were also told by this same friend if we did LTs the check engine would come on but given I found them with EGR I was doubtfull of this.
Long Tubes with EGR, High Flow Cats, Flow masters?
Logan487 is offline
Old 10-20-2013, 06:49 PM
Daehawk
Daehawk's Avatar
You can check out what mine sounds like if you want. Its linked in my sig there. I have long tubes, no cats,off road H-pipe, and a dual exhaust...all of it are MAC products.
Daehawk is offline
Old 10-20-2013, 07:48 PM
Logan487
Logan487's Avatar
What muffler combo do you use with that?
Logan487 is offline
Old 10-21-2013, 12:01 AM
Daehawk
Daehawk's Avatar
It was on there when I picked it up. from what i can gather it is...
http://shop.macperformance.com/MAC-F...m-TK9624NR.htm
Its a true dual setup..not the Y-pipe for a V6. It connects right to the LTs. Ill see about getting a better look at it next time Im out there.
Daehawk is offline
Old 10-21-2013, 07:25 AM
BabyGT
BabyGT's Avatar
I can testify you will be 100 percent fine with just 2 cats, that's all I have and 2 resonators with a true dual h-pipe setup.
BabyGT is offline
Dokilar
15
10-16-2015 08:13 PM
09-30-2015 12:39 PM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
tj@steeda
Steeda Autosports
09-24-2015 09:18 PM
Quick Reply: Exhaust Choices?
