351w alternator mounting help
Old 01-12-2017, 09:33 PM
ctross
ctross's Avatar
Default 351w alternator mounting help
Can anyone send me a pic of their 351w engine and how the alternator is installed?
I have a couple different brackets I bought of ebay, both with different sized spacers, and bolts, etc. I just can't seem how to figure out how to mount if properly, nothing seems to work. both say they were for a 351, but both came with instructions for a 289/302 (go figure).
Does it belong on the driver or passenger side?
ctross is offline
Old 01-13-2017, 09:05 AM
69mach1377
69mach1377's Avatar
Mine is on the passenger side, not sure if any pix in my sig link will help but check them out.
69mach1377 is offline
Old 01-13-2017, 09:47 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
You can drive yourself nuts trying to figure out SBF brackets & pulleys if you have a mismatched setup so you need to decide which you want to use and get a complete setup. What bracket setup are you using? 69 or 70 and later? They are different.
There is a particular bracket that is needed for the 351W alternator in both cases vs the 289/302. It mounts on the head passenger side head.
Here is the bracket needed for the 1969 alternator setup:
And this is the one used for post 69:
fastbackford351 is offline
Old 01-15-2017, 05:18 PM
Mustangs of Illinois
Mustangs of Illinois's Avatar
Here is mine, hard to see. But mine uses the bracket like the top one shown above. I got it from a Bronco site.
Mustangs of Illinois is offline
Old 01-23-2017, 07:53 AM
teeeeg67
teeeeg67's Avatar
In my opinion the easiest way to avoid the headache that is pulley systems is to buy a kit that will handle everything. Like from march. You pay a little more but everything is included. Here is my march set up with a 1g alternator. It came with the proper spacer and bracket to attach to the head
Attached Thumbnails 351w alternator mounting help-photo120.jpg   351w alternator mounting help-photo137.jpg
teeeeg67 is offline
Old 01-23-2017, 04:18 PM
No interference problems with the alternator sitting that high up ?
Should be real close to the upper hose !
Old 01-23-2017, 06:54 PM
teeeeg67
teeeeg67's Avatar
Upper rad house was an issue only because the kit calls for a thermostat housing that looks straight up. But a friend fabricated me some stainless radiator hoses. Solving a that problem
teeeeg67 is offline
