Charging system
Charging system
Hi guys, I recently replaced alternator and battery. And the car still won't charge. I have 12 volts coming from exciter wire and 12 to the gauge and ohm out the main wire. When I replaced it. It charged for 5-10 minutes then cut off. And wouldn't come back on at all. i pulled it off, cleaned where it grounds and put back on and same thing just lasted 20-30 minutes this time before cutting out. Help Any advice appreciated.
Duuuuddeee, why are you starting two threads about the same issue in the same forum??
https://mustangforums.com/forum/4-6l...or-issues.html
All you're going to do is confuse everyone or yourself which helps no one and is just annoying.
