On the right track?
Old 01-24-2017, 12:46 PM
Jekyl
Jekyl's Avatar
Default On the right track?
Hey guys, novice here doing my research and I have a few questions. At the end of the day I'm looking to turbo my GT. But that's in the future not right now, but I do want to make sure that I'm starting off on the right foot with buying the right parts. As of now I have a catback exhaust only. My next project is to get long tube 1 3/4in offroad headers, possibly the 350 intake manifold (yes or no? Necessary? Thoughts?) and a lund intake manifold tune integrated with ghost cam. I've read a few threads about the aftermarket CAI and most seem to be in favor of the stock CAI. Am I going in the right direction as far as the intake and exhaust setup for a turbo in the future?
Thanks!
Jekyl is offline
Old 01-24-2017, 02:44 PM
proeagles
proeagles's Avatar
You didn't say what year your car is. If you are going turbo, don't mess with any other intakes as the kits will be designed for the stock setup. Why turbo and not a supercharger with a warranty? Superchargers make power from idle and the so called parasitic drag is not that much of deal at 650+hp.
proeagles is offline
Old 01-24-2017, 06:42 PM
Jekyl
Jekyl's Avatar
2016. turbo..just preference. I've always been a fan of the turbos. And most mustangs I've seen have superchargers..and for a good reason I'm sure, but I like being different (as long as its not detrimental to the car.)
Good to know about the stock CAI with the turbo setup.
As far as my shopping list, does anything standout as unnecessary or a wrong part?
recommend the gt350 intake manifold?
Jekyl is offline
Old 01-25-2017, 08:25 AM
proeagles
proeagles's Avatar
Assuming you have a professional dyno tune, the gt350 intake would be fine. My point about mixing and matching intakes and throttle bodies is that if you buy a "turbo kit" with a tune it will be designed for the stock engine and may not account for the increased flow of an alternate setup.
Old 01-25-2017, 03:01 PM
movielover40
movielover40's Avatar
Turbos need back pressure to work properly.
If you go turbo leave exhaust stock.
movielover40 is offline
Old 01-26-2017, 12:12 AM
Spork3245
Spork3245's Avatar
If you want to truly be different, you could be the first to twincharge a coyote motor.
Spork3245 is offline
Old 01-26-2017, 05:24 PM
jeskam
jeskam's Avatar
You'll be wasting money buying headers since you'll be replacing them when you hang that snail on each side.. unless of course you're going with some sort of remote set up. Ditto on the intake comments.. it will all need to be changed out when you do the turbo set up.
jeskam is offline
Old 01-26-2017, 05:29 PM
jeskam
jeskam's Avatar
As a second note... if I were planning on doing any sort of serious power adder in the distant future, I'd focus on things that will need to be upgraded then but can be done now piecemeal at a lower cost.. you'll want to stiffen just about everything.. from suspension and engine/trans mounts and upgrading the clutch and flywheel prior to 'charging of any kind will save you from being marooned on the side of the road a week after you finish your install and can't keep your foot out of the gas.... more power/twist is going to equal a sloppy shift somewhere in the range so stiffening that shifter linkage/trans will help quite a bit as well.
jeskam is offline
Old 01-28-2017, 07:54 AM
darkmach1
darkmach1's Avatar
If turbo is for sure, leave the car as is, get a tune if you must have some added power, just use the same tuner that you will use when you go turbo. Add some suspension pieces like springs, cradle lockout, bushings,etc. Then save for the kit you want. Don't get headers as those will have to go. Don't bother installing a 1000 dollar intake manifold, the turbo will go 800-900 easily on the stock mani. Leave your catback on there if you like the sound, won't hurt your future setups as others have said.
darkmach1 is offline
Old 01-29-2017, 09:39 AM
Jekyl
Jekyl's Avatar
Leave everything mostly stock?? thats going to be tough to do..ok so now i may be leaning towards the supercharger haha thanks for your input guys! good info!
Jekyl is offline
