Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
67 Mustang Motor swap
Old 02-18-2017, 11:23 AM
E-Mann
E-Mann's Avatar
Default 67 Mustang Motor swap
I was wondering if anyone on here could give me some hindsight on a idea of putting in a 302 in my 67 mustang that has a 6 cylinder in it now. I am a chevy guy and don't know much about fords. I but a beautiful restored car its mint but the engine and breaks and all need to be upgraded, wanted advice from mustang people, I'm sure this has been done many times. The car has 5 hub wheels if that means anything.
Thank Eric,
E-Mann is offline
Old 03-27-2017, 10:33 AM
Z28KLR
Z28KLR's Avatar
Having the 5 lug setup is a nice start.
Aside from that though, I6 to V8 swap is a ton of work. I will assume that since you already have the 5 lug stuff that the rearend has been upgraded to a V8 spec 9", vs the I6 7.7" or whatever it is (which will break with a V8 in front of it, sooner or later).
In addition to brakes, you will need to use V8 springs and more than likely need a new transmission. I would repost your question and do some looking around over in the "Classics" section here, you should be able to find everything you need over there.
Z28KLR is offline
