04 GT replacing fuel pump
Old 03-22-2017, 01:49 PM
jdolan1291
jdolan1291's Avatar
Default 04 GT replacing fuel pump
Whatsup guys and girls, I have an 04 gt thats been in the garage since January and with the weather being nicer I went to fire it off recently and it died after running for 5 secs or so. Ive narrowed it down to the fuel pump being shot and never done an in-tank pump before so had a few questions...its got a half tank of fuel in it and because of the anti siphon these cars have im not sure how i can drain any of it. Would it be that bad to drop a half tank just using a floor jack?
Also, Ive been reading that one of the steps is to make sure the fuel lines are depressurized before removing the fuel filter...in this case because ive been cranking the engine and the fuel pump is shot does that mean the lines already have no pressure? May seem like a dumb question but i just want to make sure im not gonna get doused in gas when i take the filter off. Any other good tips for doing a fuel pump are much appreciated. Thanks for any and all help!
jdolan1291 is offline
Old 03-22-2017, 05:56 PM
WJL
WJL's Avatar
First I think 02 and up have a Schroeder valve on the fuel rail, depress it just like you would I tire valve stem.
If not the fuel pump switch sometimes referred to as an inertia switch, which shuts off fuel to the engine in the event of a collision, makes for an easy means of to relieve fuel pressure.
The switch is in the trunk, unplug the switch, start the car run until it stalls, pressure should be relieved.
If the car doesn’t start Hmmm, that could be a problem. In this case go get a hose key and disconnect the fuel line at the fuel rail, at least the gas wont drip on you.
You can siphon you just need a small diameter hose.
Couple of preliminary checks you should do before you remove the tank:
Check battery voltage, a low battery can do some funny things
Check/replace fuel filter
Check for leaks.
Check to see if the pump is working, take the gas cap off have someone turn the key to the on position you should hear a brief whirring sound for about one second.
If no noise check fuel pump fuse
If fuse is good check CCRM (constant control relay module)
Reset inertia switch.
Good luck
WJL is offline
