Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
lets see your speed density set ups
Old 02-07-2008, 10:01 PM
dimebag
dimebag's Avatar
Default lets see your speed density set ups
yea so whats everyones sd set up? hp numbers? track times?.... ill start
1988 gt hatch
4cyl springs front
strange 10 ways front
no front swaybar
15x4 rim up front
m/t drag radials(235/60/15)
pro50 shifter
frpp clutch quad
frpp headers
o/r h pipe
dumped 40 series flows
3.73s
gt40 heads
gt40 intake
comp cam
valve springs/retainers/locks
100 shot, wet.
explorer bottom end
8.8-1 compression
dyno and track times coming shortly... expected ~270rwhp, 11.90s in the 11x.xx mph area
will update w. actual times and numbers when the track opens
dimebag is offline
Old 02-08-2008, 06:14 AM
stangbanger87
stangbanger87's Avatar
Default RE: lets see your speed density set ups
1987 gt, world class t-5 , sub frame tied , strut tower brace ,ud's, clp throttle enhancer,bbk cai,king cobra clutch, jegs hardened fork ,3.73 geared,upr short throw,picking up this weekend is a gt40 intake , gt40p heads , no new cam yet (need a good recomendation)zex 150 wet waiting to go on ,an engine rebuild comeing soon as i get therest of the top end parts , i will problly pull this weekend ,eibac springs,ssm upper and lowers ,koni shocks and struts.
i need some good recomendations on a cam and tb for the gt 40 set up ,i will also be getting a set of flow balanced 19# injectors this weekend . oh the exaust it frpp headers off road h and flowmaster 40's .
stangbanger87 is offline
Old 02-08-2008, 11:28 AM
AdderMk2
Banned
AdderMk2's Avatar
RHS180cc heads
Trickflow TrackHeat Intake
Comp Cams XE276hr bumpstick
FordStrokers.com Liberator 347
Scorpion 1.72 Roller Rockers
70mm TB
30# injectors
Long tubes, O/R H pipe, SLP LM1's
Megasquirt Stand-alone EFI system
ZEX 75 shot wet
AdderMk2 is offline
Old 02-08-2008, 12:06 PM
86GreenMachine
86GreenMachine's Avatar
well mine is still stock besides Ebaich drag springs,Lakewood lower con. arms.KYB shocks up front,Super 40 series flows , 3 1\2 tips.Went 15.34 in 1\4 mile before any suspension mods.I felt i could have done better ,it was also my first time on a drag track.My hp #'s are 193rwhp and 272 rwtq.more to come!
86GreenMachine is offline
Old 02-08-2008, 12:16 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: 86GreenMachine
since you already have some suspension mods done... get some gears, and sticky tires
AdderMk2 is offline
Old 02-08-2008, 12:39 PM
86GreenMachine
Thats next on the list.Dont know if i should go with 4:10's or 3:73's ,what do you guys think i should get?.I cant stick any tires onwiderthen a 225 b/c it will hit my exhaust.Does nitto or M/T make some sticky sticky tires that will fit on my car.
Old 02-08-2008, 03:48 PM
nitrousd85
nitrousd85's Avatar
where to start
how about this car is humping 200k also
1988lx Santch
stock springs (for now)
flicked the sway bar
convo pros big 'n' little's
Mickey thompson drag radial 275/50/15's to big i know
hurstshort throw
Center force dual friction clutch fried to many king cobras
SVO quadrant
BBK long tubes
bbk h pipe No cats dont believe in em
spin thech 3 in. dumps
lakewood upper and lower control arms
3.55 gear
195 lph pump
gt-40 heads not p's fresh from the machine shop
new springs
Cobra intake on the way
bbk 70 mmT body and spacer
frpp plugs msd blaster coilcap and rotor
bbk CAI
frpp UD's
lake wood 50 50's out back lake wood 90/10's
energy suspension mounts
nitrousd85 is offline
Old 02-08-2008, 09:03 PM
67mustang302
67mustang302's Avatar
Adder, how are those RHS heads working out? I remember you had some issues installing them with the coolant ports.
67mustang302 is offline
Old 02-08-2008, 10:25 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
My car is so fast it's liftin the wheels right off the ground right this very minute.. on a nice rotary lift!!![:@]
mjr46 is offline
Old 02-08-2008, 10:33 PM
67mustang302
So fast at breakig down?
Quick Reply: lets see your speed density set ups
