SD supercharged
RE: SD supercharged
well yes and no you can switch to maf or get a mega squirt sd ecu or an xfi from fast if you want to stay sd .
both of which are spendy but worth it , after all if you go maf you will have to have the maf sensor calibrated for it anyway might as well have the good sd ecu and have it tuned for the app you want .
RE: SD supercharged
its dimebag....
and no, stock car with a 6 or so psi blower, you can stay SD just fine... pm me (dimebag, not whitefoxgt) if your really interested in doing it, ill point u in the right direction
had i not blown mine up and did a h/c/i swap on the motor i put in, ida went stock motor and a blower
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
