Yeah I noticed the vdub too. It really took it to that vette from the dig, but I figured that was driver error. But that roll race was pretty tight, the vette mighta come around him in the end.....
The op of that vid has one helluva fast car, put quite a few on that 'maro.....
Lol, that S10 needs to get an LSD. I had to watch it a couple times to figure out what was going on, but looks like he has a locker and when it unlocks he blows the one tire off.
He's pushing 40lbs, I'm far from being an expert on turbos, but wouldn't it be better to get a bigger turbo that pushes more CFM and less PSI? This is a question, not a statement.
yes, if you want ungodly lag and top end (aka big single turbo Supra). certain applications require different setups. now that little 4-banger isn't going to spool all that well down low if it had a big turbo, but the smaller turbo running higher boost can be quite a combo
stone you are 100% correct, he could get a turbo slightly larger than that one and spool it with a small shot of nitrous and then launch OFF the N20 and the turbo is spooled yield more efficient results and possibly more power.
