Suspension Ask all of your general suspension questions here!
MM Caster Camber Plates Help
Old 03-28-2013, 03:27 PM
WhiteFaleen2001
WhiteFaleen2001's Avatar
Default MM Caster Camber Plates Help
So I installed my MM CC plates a while back and am unable to positive camber at all. I have definitely installed them correctly and made sure that they are set up for positive camber and not the negative side.
It isn't that I necessarily want positive camber, but I am trying to not have it as negative as it currently is.
My question is has anyone run into a similar problem? Can I just drill out my wholes wider to make my adjustment room larger?
WhiteFaleen2001 is offline
Old 04-27-2013, 10:50 AM
wmfateam
wmfateam's Avatar
Late reply but did you contact Maximum? I have had zero issues with their customer service.
wmfateam is offline
baddog671
07-26-2016 01:20 PM
Explosive
10-02-2015 07:45 AM
mdg
10-01-2015 07:04 AM
winner99
09-30-2015 07:04 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: MM Caster Camber Plates Help
