Easiest way to raise rear of 2016 GT
In order to raise the rear without altering the ride quality then you will need to either raise the lower spring bucket up off the lower control arm, lower the upper spring bucket from the chassis, or a combination of the two. This will allow you to use the stock spring
You need to look at trucks if you want to raise the vehicle, they have it figured out. The difference is they can just use a body lift that raises the body off the chassis.
The trucks is where I got the idea for the link to the rubber spacer that goes under the spring to lift it an inch, I mean it don't get easier than that.
Honestly, I haven't even looked under my new Mustang yet as I've been very busy lately. I've never restored a car with a independent rear suspension. I know the obvious ways, but I thought possibly the suspension experts might have some ideas with the IRS I don't, or even an know aftermarket part that will raise the car without changing the spring rate. With the classic Chevys I've restored, modified spindles can be used to lower or raise a front suspension without affecting the spring rate.
I didnt call you a liar you old fool. I stated that someone with as much knowledfge about cars as you claim to have should know how to modify them. I cant prove that your claims are true or false as I dont know you, I just know what youve claimed to do.
IRS and SRA suspension do exactly the same thing, just one is independent of the other sides actions.
Weight pushes down, spring compresses, spring relaxes, weight moves upward, shock dampens/controls bounce, repeat.
Having said that it's much more common to lower the car for better road holding, so there may not be much aftermarket support for raising it.
I think the spacer idea has been suggested at least twice. A spacer will not affect the spring rate. The only way to do that is change the spring. One thing about some IRS setups (not sure about the Mustang) but you may have to make some kind of camber correction that, with a live axle, would not be needed.
Thanks for the response!
"You would think someone that has restored and rebuilt as many cars as Mr D has claimed to have done would be able to come up with something."
I think I've made my point, so I'm done! Your my favorite poster too!
A little up in the rear would look better! Sorry, but I'm not sure Roush can improve on this one in looks! IMO.
