Injectors on a 98 Cobra
For now I am just planning on running the long tubes, x pipe, gears, tune, pullies, CAI etc. Just mainly bolt ons.
Should i change the lb injector from the stock lb? Isnt stock like 24?
Even if i shouldnt move up how often should you change injectors?
My car has a little over 70k but it is 12 years old. I have been pretty much replacing everything just because I am picky like that haha.
I didnt know if i should change the injectors or not with them being 12 years old
Thanks in advance
Jim
Thanks in advance
Jim
ya they will be fine unless you want to supercharge it... it wouldnt hurt to clean them though with some sea foam or whatever ypur choice of cleaner is...its real easy to get some bad gas....also i know this is alittle off topic but change your fuel filter...we changed it on a buddys car and ran some fuel through it the other way and it was pure black i think its totally worth it test it for yourself... then clean the injectors
