Need help with my new ride.
Recently purchased a 1995 Mustang GT
The rear spoiler is cracked. Are they all the same from 1998 to 1995? I was looking on Row52 and seen about 3 that I can get but will they all match up?
Also the car is stuck in gear. When I let out the clutch it starts engaging the gears and tries to go even when in neutral. Does it look like I need to rebuild the transmission or is it a simple fix?
Last thing: The AC work but it only comes out of the defrost? I can not select anything else so what is the root cause of this?
Thanks and look forward to all the knowledge everyone has on here!!!
I would think the spoilers would match because to my knowledge the body was unchanged during this time. So as long as it's an OEM design it should be OK. I'm not sure about your transmission or A/C. Might be an obstruction in the ducts, or a fan problem. Probably not a quick fix though as it could involve taking out the dash. A friend of mine was talking about a similar problem on his Bronco not too long ago. He tore the dash out to get to the problem. With all these problems getting it checked up by a shop might not be a bad idea.
JoshyGT
09-19-2017 08:52 PM
