Flat Plane Crank
http://articles.sae.org/13709/
http://www.edmunds.com/ford/mustang/...voodoo-v8.html
I still wonder if the Coyote with the stronger pistons, rods, crank, etc. supercharged for higher RPM's wouldn't be a hell of an engine in a Mustang. I might reappear in a Shelby. Having said that, obviously the Flat Plane Crank must be the best engine for the GT 350, but I'm impressed with the Coyote for street use!
I'm sorry, but to my "Old Guy, Old School" ears the Coyote has a much better sound than the Flat Plane Crank, but that's just individual taste! If I win the Lotto, I'll get one of each... but I'd have to start playing the Lotto I guess!
Formula 1 V8s got up to 19,000 rpm by being 1) 2.4 liters, and 2) using a long conrod and short stroke design.
the driver for safe upper RPM limit is peak piston speed, which is determined by the ratio of the connecting rod length to the radius of the circle drawn by its rod journal. You want to keep your peak piston speeds below a certain number (can't remember what it is) or else bad things start to happen. at 5.2 liters the Voodoo is probably pretty close to its limit with an 8250 rpm redline; it's probably got a little bit of margin but not much more.
Interesting post jz78817! I used to build small block chevys for classic cars. I found the whole deal on those "Old crude engines" was in doing the heads perfectly... sparing nothing. That extra care with all the air, fuel & spark stuff right & a good balanced engine would hit much higher RPM's even with hydraulic valves. Too many small block chevy guys would cheap out on the heads reusing springs & values etc. to save a buck, & wonder why they didn't get a screaming little engine! Now that size engine gets twice the power per cubic inch! Who woulda thunk it back in the days of '57 Chevy's! What was that Ford secretaries' car they put on a Falcon frame in '65? I can't remember what that was called! A horsey or pony or something? Some guy name Shelby came along & saved it from the secretaries!
