WTT 89lx street/drag car for Sport bike
The car is a 89 Mustang Lx orginal v8 car...
I have over 15k in reciepts all work performed by rocketperformance. The car is located in hampton roads (Newport News) VA. The car is no joke and some of the best of the best stuff on it.
engine On motor the car put down 329 RWHP and 330 RWTQ on Spray the The put down 460 RWHP and 475 RWTQ only 150 shot.The car has only 5 passes on the motor the car and the car was just together in the last 3 months everything is basically brand new inside the motor. I have reciepts totaling over 15k into the car all work was done by one shop Called ROCKET PERFORMANCE. The car runs
10:90s consistantly on 150 shot. Car weights 3085 with drive in it. 225 lb drive.and runs 12.50s on motor. THe car pulls the wheels about 2ft off the ground just fyi.
The car is still streetable and is a fun car to drive. Here is a break down there is more probably more just cant think off the head right now picture are below also. ASKING 8800.00 or I would be willing to trade it for a nice street bike. Prefer a 1000cc may consider trade and cash too. I miss the sport bike and the wife wont let me have both. So go figure.
SLIDE SHOW
http://img208.imageshack.us/slidesho...7605113dp.smil
306 compression 9:5:1
dss rotating assembly
dss 1.7rr
edlebrock victor 5.0 upper and lower intake
edlecrock performer heads 2.02 ported and polished with ferrea valves and stronger springs
Screw in freeze plugs
All ARP hardware was used.
Main Girdle
Cam is Anderson lift 524/544
newer 50oz balance
new undrive pulleys
aluminun radiator with dual electric built in fans
70 mm throttle body with 70 mm spacer
new mac cold air intake
Fms 30lb injector
C&L 80mm mass meter
Aeromotive fuel pressure Regulator
new power steering pump relocated
mellon High volume Oil pump
FMS valve cover New spark plugs, wire etc.
MSD COIL
Hurst Line Lock
new timing chain new water pump and cover
walboro 255lb fuel pump
Transmission
PA C4 built transmission is a Super comp no transbrake,Reverse manual valve body brand new trans cooler and sfi flywheel
lines.It has the best of the best inside. 2500 stall
Exhaust
Mac headers 1 5/8
with mac off/rd H pipe
flowmasters with dumps
Rear end
FMS 3.73 with a New just put track lock
Nitrous system a NX Big shot solenoids, kit is complete with
Bottle heater, Purge, Fogger, Pressure Gauge, bottle custom painted.
Suspension
Lakewood 90/10 up front
Moroso Drag springs
Strange Adjustable rear shocks
Moroso drag springs in the rear.
BBK subframe connectors.
UPR upper and lower control arms
Wheels
Weld wheels Big and little with new tires up front
and New tires in the rear 26inch tall tire.
Other stuff:
The car has a 8pt roll cage just recently put in.
3 cervinis cowl hood.
Monster Tach, with oil pressure gauge and water temp gauge
and nitrous pressure gauge.
New black carpet, racing seats,Brand new B&M ratch shifter.
Cervinins fiber glass hood. 3 Cowl hood
Window tint
Brand new battery.
hood pins.
driver shaft loop
with a fms aluminun driveshaft.
White face gauges
http://img84.imageshack.us/my.php?image=pb290472wm8.jpg
SLIDE SHOW
dss 1.7rr
Main Girdle
newer 50oz balance
new undrive pulleys
Fms 30lb injector
C&L 80mm mass meter
MSD COIL
Hurst Line Lock
Transmission
Exhaust
Mac headers 1 5/8
Rear end
Suspension
Moroso Drag springs
Wheels
Other stuff:
Window tint
Brand new battery.
hood pins.
driver shaft loop
White face gauges
RE: WTT 89lx street/drag car for Sport bike
i have a sport bike, its not a 1000 but it runs as well as one. it is a 98 gsxr 750, its all custom and all new, from front to rear. i have well over 8000.00 in new parts and rebuild this last summer alone, it is a remarkable looking and very fast bike. if interested email me at erinjr25@aol.com i can send pics.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
