Tuners
RE: Tuners
ORIGINAL: 03YellowPony
Nope..by RPM's
ORIGINAL: mustangman02232
yes but if you want to raise shift points doesnt it only do it by MPH?
That's the beauty og the SCT. they will put a tune in for 87 89 and 91+ gas. Then it's your choice
i want to just be able to do shift points and firmness, along with limiter removal and gears when i get them, which one can i get away with using regular, and would they still tuen a little?
edit <<<woo hoo 1989, im stayin on here tonight unitl i hit 2k posts
RE: Tuners
ORIGINAL: Protoman84
Who wants to explain what the hell you guys are talking about for the n00b?
RE: Tuners
We are talking aboot flash tuners. They enable you to change parameters of the cars ECM. Like timing, air/fuel mix, taking off the speed limiter, changing the auto tranny shift points, and pressure, adjusting the engines rev limiter, and more. They plug into the OBDII port under the dash.
RE: Tuners
Whoa! That sounds fun, but I know if I touch mine I'll mess up my car. Thanks for the response!
RE: Tuners
RE: Tuners
REALLY?
Where should I start?
Would it take awhile?
they are pretty much idiot proof if you follow the directions that we were to give you off the forum
It takes aboot 5 minutes or so to install the pre programmed tune.
RE: Tuners
ost @$400.00..unless you can find one on E-bay, or on sale.
