What should I do?
What should I do?
Hey guys my birthday is coming up and I am asking for a new paint job for my 3.8L 1995 mustang since the crappy paint is all peeling and later I was hoping of getting some nice cobra rims for it. But performance wise I dont have a clue what to do. So I was wondering are there any simple mods I can do or buy. The only thing I really know what to do is to get a cai from auto badges. I would really appreciate your input guys thanks.
RE: What should I do?
THIS SHOULD KEEP YOU BUSY FOR A WHILE
SN-95 V6 Mods
Air Intake
1.) MAC Cold Air Intake $170 @ autobadges.com
4.) 80mm Cobra MAF set to 24lb injectors
5.) 56mm BBK Throttle Body $249 @ V6mustangstuff.com
Engine
1.) ASP 25% Size Reduced Crank Pulley $72 @ autobadges.com
2.) Billet Aluminum Water Pump Pulley $65 @ rpmoutlet.com
3.) ASP Underdrive Pulley Belt $35 @ autobadges.com
4.) Diablo Predator Tuner 96-04 $399 @ hillbankmotorsports.com
5.) BBK Chrome Valve Covers $329 Silver $199 @ hillbankmotorsports.com
6A.) Stage 2 (AUTO) Powerpack $1725 @ supersixmotorsports.com
6B.) Stage 2+ (MANUAL) Power Pack $1950 @ supersixmotorsports.com
6C.) Stage 2+ (AUTO W/STALL) Power Pack $1950 @ supersixmotorsports.com
6D.) Stage 3 (FORCED INDUCTION) Power Pack $2375 @ supersixmotorsports.com
6E.) Basic Split Port Intake Swap Kit $720 @ rpm-mustangs.com
6F.) 99+ Stage 2 (AUTO) Powerpack $1800 @ supersixmotorsports.com
6H.) 99+ Stage 2+ (MANUAL) Power Pack $2200 @ supersixmotorsports.com
6I.) 99+ Stage 2+ (AUTO W/STALL) Power Pack $2200 @ supersixmotorsports.com
6J.) 99+ Stage 3 (FORCED INDUCTION) Power Pack $2350 @ ssms^^^
6K.) Split Port Swap Gasket Kit (no intake or heads) $310 @ rpm-mustangs.com
8.) 24lb Fuel Injectors $279, 30lb $275, 42lbs $359 @ jegsperformance.com
9.) Stud Mount Adjustable Roller Rocker Arm Kit $495 @ supersixmotorsports.com
10.) Cam Thrust Spacer Roller Bearing Kit $150 @ supersixmotorsports.com
11.) Spring Retainer Kit $225 @ supersixmotorsports.com
12A.) Forged Stock Internals $1200 @ supersixmotorsports.com
12B.) Forged H Beams W/ 351W Rods $1600 @ supersixmotorsports.com
13.) BBK Fuel Pressure Regulator $109.99 @ brothersperformance.com
Forced Induction
1.) Nitrous Oxide approx $500 @ jegsperformance.com and many others
2.) Vortech Supercharger approx $3500, see vortechsuperchargers.com for info.
Ignition
1A.) Red/Blue/Yellow 9mm Spark Plug Wires $70 @ autobadges.com
1B.) Chrome 8mm Spark Plug Wires $100 @ autobadges.com
2.) see msdignition.com for the rest of your ignition needs
Exhaust
1A.) JBA Silver or Titanium Short Tube Headers $640.97 @ hillbankmotorsports.com
1B.) JBA Short Tube Headers $460.72 @ hillbankmotorsports.com
1.C) JBA Chrome Short Tube Headers $349.99 @ brothersperformance.com
2A.) 2.5†V6 O/R X-Pipe see pypesperformance.com
2B.) MAC 2.5†V6 O/R H-Pipe $160.50 @ hillbankmotorsports.com
2C.) 2.5†V6 High Flow Catted X-Pipe see pypesperformance.com
2D.) 2.5†V6 High Flow Catted H-pipe see pypesperformance.com
3A.) Magnaflow 2.5†GT Cat-Back Dual Exhaust $469.99 @ brothersperformance.com
3B.) Borla 2.5†GT Cat-Back Dual Exhaust $699.99 @ brothersperformance.com
3C.) Bassini 2.5†GT Cat-Back Dual Exhaust see bassini.com
3D.) Flowmaster 2.5†GT Cat-Back Dual Exhaust see flowmaster.com
4.) MIL Eliminators (for O/R systems only) $61.95 @ hillbankmotorsports.com
Drivetrain
1A.) Ford Racing Posi-Traction 7.5†Differential $199 @ v6mustangstuff.com
1B.) See drivetrainspecialists.com for more durable options
2A.) 3.73 Motive Performance Plus Gears $ 149.99 @ mustangtuning.com
2B.) 4.10 (Moderately Moded Apps Only) Motive Performance Plus Gears $149.99 mt
2C.) 3.73 Ford Racing Gears $199.99 @ v6mustangstuff.com
2D.) 4.10 (Moderately Moded Apps Only) Ford Racing Gears $209.00 @ v6ms
3.) Motive Bearing Kit $74 @ mustangtuning.com
4.) 23 Tooth Speedo Corrector -
Transmission Auto
1.) High RPM Stall Torque Converter see mustangsunlimted.com
2.) Shift Kit see mustangsunlimted.com
Transmission Manual
1.) Steeda Tri-Ax Short Shifter $179 @ autobadges.com
2.) Shifter Gasket Set $9 @ autobadges.com
3A.) Spec Stage 2 Clutch $333.95 @ mustangsunlimited.com
3B.) Spec Stage 2+ Clutch $399 @ mustangsunlimited.com
3C.) Spec Stage 3 Clutch $499 @ mustangsunlimited.com
Suspension
1.) Steeda Caster Camber Plates $229.95 @ autobadges.com
2.) Steeda Lower Control Arms $295.95 @ autobadges.com
3.) Steeda upper Control Arms $295.95 @ autobadges.com
4.) Steeda Lower Subframe Connectors $89.95 @ autobadges.com
5.) Eibach Pro Spring Kit $224.95 @ autobadges.com
6.) Tokico D-Spec Shocks $629 @ autobadges.com
7.) Ford Racing (Cobra) Break Kit $819.88 @ mustangsunlimited.com
8.) 17†or 18†Rims see tirerack.com
Body
1.) Body Kits see mrbodykit.com, cervinis.com
Interior, Exterior, and Under Hood Visuals
1.) See mustangsunlimited.com, mustangtuning.com, and autobadges.com
SN-95 V6 Mods
Air Intake
Engine
Forced Induction
Ignition
Exhaust
Drivetrain
Transmission Auto
Transmission Manual
Suspension
Body
