Turn signal too fast.
Old 12-20-2006, 01:31 AM
Ultimeas
Ultimeas's Avatar
Default Turn signal too fast.
Driving home from a party tonight, noticed my right turn signal going about twice as fast as my left (normal). Just started doing it tonight. The flasher on the dash blinks twice as fast as the left, and so does the rear and front turn signals. Has to be whatever controls the turn signal right?
What could be the problem here?
03 Mustang coupe v6 with 51k miles.
Ultimeas is offline
Old 12-20-2006, 01:33 AM
Xemeth
Xemeth's Avatar
Default RE: Turn signal too fast.
Could be cause one of your left signals (front or back) is out. Happens on my girlfriend's car all the time, cause her front signals (both, lol) are both out.
Xemeth is offline
Old 12-20-2006, 02:09 AM
amrcnidyot
amrcnidyot's Avatar
yea, when a bulb goes out it flashes really fast.one of your bulbs is probably out. just turn on the signal and look around the car at each light and see wich is out. get the bulb # off the bulb or outa your owners manual, go get a new one at walmart or autozone or somehtin, and install the new bulb. and try not to touch the glass on the new bulb with your fingers when you put it in. they are said to ware out faster if you do.
amrcnidyot is offline
Old 12-20-2006, 02:18 AM
jthorn9
The Godfather
jthorn9's Avatar
It means that either the bulb is out, or the control modual that controles the turning signal is going out.
jthorn9 is offline
Old 12-20-2006, 03:53 AM
00StangV6
00StangV6's Avatar
my cars been doin that for like a month now. didnt really think much about it. glad u posted this
00StangV6 is offline
Old 12-20-2006, 11:43 AM
00raging stang
00raging stang's Avatar
yeh one of ur bulbs are out
00raging stang is offline
Old 12-20-2006, 11:45 AM
Jefferson
Moderator
Jefferson's Avatar
Just incase you are still not sure....a bulb is out.
Jefferson is offline
Old 12-20-2006, 01:35 PM
mustangman02232
mustangman02232's Avatar
ok so if the bulb is blinking to fast then it might be a problem, you see, you have a bulb out
mustangman02232 is offline
Old 12-20-2006, 01:40 PM
Stang562
Stang562's Avatar
The bulb is out you guys say?
Stang562 is offline
Old 12-20-2006, 01:45 PM
Jefferson
Moderator
Jefferson's Avatar
The bulb may be out, I'm not sure because I can't see it.
I can see this thread however and it is becomming a ***** fest.
[sm=lockeddance.gif]
Quick Reply: Turn signal too fast.
