1/4 mile times
Old 12-27-2006, 06:13 PM
hpwrestler220
hpwrestler220's Avatar
Default 1/4 mile times
stock v6 2001 mustang with catback dual exhaust..what will that run in the 1/4 mile?
v6 2001 mustang with catback dual exhaust/3.73 gears/ sct xcal II tuner/ cold air intake..what will that run in the 1/4 mile?
just any close numbers would be great. thanks
hpwrestler220 is offline
Old 12-27-2006, 06:15 PM
98Ga
98Ga's Avatar
Default RE: 1/4 mile times
between 13 and 14
98Ga is offline
Old 12-27-2006, 06:52 PM
SilvrStang
SilvrStang's Avatar
PROOF plz,i call BS on runing high 13s and low 14s with those mods,never seen a sixer do it
SilvrStang is offline
Old 12-27-2006, 06:54 PM
fallfast90
fallfast90's Avatar
3.73's, duals, intake, and tune will probably get you low 15s for auto and high 14s with stick.
fallfast90 is offline
Old 12-27-2006, 07:05 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
I ran a 15.07 on intake and programmer only with street tires in my 6, and that was on my ****ty 70K mi clutch. I didn't have a shifter or anything, plus I had about 200lbs of stereo in the trunk.
Ryan
RyansQuick6 is offline
Old 12-27-2006, 07:07 PM
Xemeth
Xemeth's Avatar
ORIGINAL: 98Ga
between 13 and 14
I suggest knowing what you're talking about. Read Durr's signature.
Xemeth is offline
Old 12-27-2006, 08:38 PM
jthorn9
The Godfather
jthorn9's Avatar
Well the exhaust really isn't gonna improve your times too much, probably mid 15s if you're a good driver and a manual, low 16s to high 15s auto.
All the mods listed will put you in the high 14s, to low 15s if you're decent manual, mid to low 15s if you're auto.
jthorn9 is offline
Old 12-27-2006, 08:47 PM
mvr
mvr's Avatar
ORIGINAL: SilvrStang
+1 a bone stock 99-04 GT is low 14's with a decent driver...
mvr is offline
Old 12-27-2006, 09:01 PM
Flake6899
Flake6899's Avatar
Maybe he meant with a shot of nitrous =/
Flake6899 is offline
Old 12-27-2006, 09:16 PM
RyansQuick6
Reverse Gear Member
In the 3 passes I got at Baytown, no traction 1st & 2nd, I was able to run a 15.07 @ 90.7mph with a 2.08 60ft
That was street tires, intake and programmer. I don't see how people can't make it into the 14's with these few little mods and traction. I probably could have hooked had the track not been torn up by radials and I had my Nittos on, which would have drastically improved my time.
Bone stock, it ran a 10.8 1/8th mi @ 63.7, and with the programmer andintake it ran a 9.6 @ 72.6 mph, so that over a second in the 1/8th.
Quick Reply: 1/4 mile times
