awful scratching noise
I have done alot of research on the forums about this problem.. And none of them give me an answer for exactly the problem I'm having.. This god awful scratching sound is coming from the front right section of my car.. I have had the rotors/calipers/pads all replaced and it still does it.. When I am driving at about 20 and deaccelarating it gets godawfully loud.. and even when i stamp on the gas pedal it still makes the sound, so this almost leads me to believe it might be suspension or an axel problem. Also.. when I'm on the highway at about 60 and go over a bump, it will scratch at me at the peak of the bump, but when i'm driving smooth, no acceleration, no deacceleration, it makes no sound at all.. I'm gonna have to pay for a mechanic to look at it if I can't get it fixed soon..
RE: awful scratching noise
hmmm... What I think it could be is the shocks and or struts are worn and scrape when the botton out. and when you press on the breaks the front end goes down bottoming them out. and fast excelleration puts the rear end down. and obviously the bump. I would try replacing the springs and the shocks and struts.(it can't hurt if it doesn't solve the problem, and if it does it will be great) I say it might be this because my friend whent over a speed bump at 50 mph and now when ever he hits a slight bump his suspesion bottoms out. it's not a pretty sound.
Not really, as speed increases it can push the shield away from the rotor until you slow back down, its easy to check, just turn the wheel all the way out and look at the back.
^ haha.. Thanks for the tips guys.. I suppose a complete new front end tweaking is necessary. It's not the splash shield, that's of course one of the first things I checked :/. I hope to god it's not my axel..
ORIGINAL: Brianzeke007
Im not a mechanic but it might be a rabid racoon....like stuck in engine...most likely hungry and when you hit high speeds the wheel scrapes his *** causing him to flip a hoot
