Steering Wheel Vibration
Old 10-07-2007, 06:47 PM
Ares
Ares's Avatar
Default Steering Wheel Vibration
Alright so im getting a prettysevere vibration in my steering wheel. Its the worst between 40 and 55 mph but i can feel it anytime. I know its not my alignment, i just had that done, but i dont know what else it could be.If you guys have any idea what could be wrong id really appreciate the help.
Ares is offline
Old 10-07-2007, 08:44 PM
johnt2k7
johnt2k7's Avatar
Default RE: Steering Wheel Vibration
need your tires balanced
i just did mine because i had a wheel weight falloff and i had a vibration
johnt2k7 is offline
Old 10-07-2007, 09:14 PM
actionstang
actionstang's Avatar
that could tire balanced, but i also had a buddy with two bent rims and that gave him a horrible vibration at about 55-60 mph.. i was drivin behind him one day and his car just started cutting back and forth and it looked like he was about to loose control. hopefully its just tire balance cuz thats alot cheeper to fix
actionstang is offline
Old 10-07-2007, 09:25 PM
Ares
Ares's Avatar
My rims are fairly new so that shouldnt be the problem. But ive already had my tires balanced andIve had the damn thing at Ford for a week and they told me they couldnt find anything wrong with it.
Ares is offline
Old 10-07-2007, 09:26 PM
actionstang
time to find a new place to get ur **** checked out...
Old 10-07-2007, 09:30 PM
Ares
Ares's Avatar
Yeah im a little skeptical about how hard they really tried to say the least.
Ares is offline
Old 10-07-2007, 09:55 PM
MantaDreams
MantaDreams's Avatar
internal tire failure and bent rims have been my experience with the problem u describe
MantaDreams is offline
Old 10-07-2007, 10:36 PM
raz54
raz54's Avatar
It could be like MantaDreams said and be a tire coming apart inside but still look good. If all your tires are the same size try putting one of the rear tires on the front. If the vibrations stops you know which one is doing it. I bought a new set for my Ranger and it did that. They tried 6 times to balance it and never was fixed so they finally replaced it.
raz54 is offline
Old 10-07-2007, 10:48 PM
XxXRacingUnleashed
XxXRacingUnleashed's Avatar
wheel bearings, or tie rod ends could be a factor, get it up on a jack and wiggle the tire up and down and side to side at all angles if there is play then it is either one of those. is this happening on acceleration or decell? and is it auto or standard?
XxXRacingUnleashed is offline
Old 10-07-2007, 11:00 PM
98Ga
98Ga's Avatar
yeah it sounds like your wheel bearings if its only doing it when your on the brakes then its your rotors
98Ga is offline
Quick Reply: Steering Wheel Vibration
