Aftermarket spark plugs, worth it?
Old 09-23-2008, 01:01 AM
StillDyl
StillDyl's Avatar
Default Aftermarket spark plugs, worth it?
so what exactly is the benefit of "upgrading" spark plugs. and if i do do it what kind should i get
(98 v6 5 speed)
StillDyl is offline
Old 09-23-2008, 01:11 AM
eaglecatcher
eaglecatcher's Avatar
you can get a hotter spark. Not really needed on a stock engine... I wouldn't worry about getting anything too fancy, just some decent quality (I like name brands) plugs and wires. keep it running right really.
eaglecatcher is offline
Old 09-23-2008, 06:23 AM
The Yellow Pinto
Guest
Posts: n/a
got some really good halo plugs for sale, still, in the classified section. would work great on your car.
Old 09-23-2008, 06:26 AM
mustangman02232
mustangman02232's Avatar
or, you can get a cooler plug pending your application. autolights are fine, halos are good plugs to.
mustangman02232 is offline
Old 09-23-2008, 09:15 AM
Blainestang
Blainestang's Avatar
Basic Autolite Coppers FTW
Blainestang is offline
Old 09-23-2008, 09:38 AM
moontang
moontang's Avatar
since we are on the subject has any one tried the pulse plugs they keep advirtising in popular mechanics iv seen them advirtised else where also
moontang is offline
Old 09-23-2008, 10:15 AM
The Yellow Pinto
Guest
Posts: n/a
^^^ if i remember those correctly, those plugs are HELLA expensive. i think you can get a whole supercoil, bigger wires, and good plug set up for the price of those.
Old 09-23-2008, 10:17 AM
The Yellow Pinto
Guest
Posts: n/a
My God, just googled them....25.00 PER PLUG. yeah, you can get a accel super coil, a set of msd 8.5 wires, and iridium plugs and gap them to .060 for that price, and guaratneee that setup will outperform the pulstars.
Old 09-23-2008, 11:32 AM
stevenc1010
stevenc1010's Avatar
i've got autolite platinum that im waiting to put on my car. i've heard people here say copper is the way to go, however, i was at the dealership recently and they put platinum plugs in any cars they work on. platinum will last longer and produce a longer consistent spark than copper. ive only heard bad things about triple platinum plugs and other plugs in that category though.
you shouldn't need to spend more than $8-9 a plug, unless your engine calls for it.
stevenc1010 is offline
Old 09-23-2008, 12:49 PM
mustangman02232
autolights are fine for $1.10 a plug or whatever, if you want something a little more fancyer then halo plugs are also good plugs for $6.99 ea. there is no need to spend more then that
Quick Reply: Aftermarket spark plugs, worth it?
