split port swap kit
Old 05-12-2009, 05:05 PM
my94pony
my94pony's Avatar
Default split port swap kit
supersix is out of split port swap kits is there anywhere else i can buy this online or does anyone have a list of what is needed? i have a mustang salvage yard by me but i need to know exactly what I'm looking for.
my94pony is offline
Old 05-12-2009, 05:54 PM
zinsavage123
zinsavage123's Avatar
nowhere is going to have much due to the economy. Ask tom at ssm and he will tell you what is needed write it down while he is telling you. You need the upper and lower intakes, modified fuel rail, throttle cable and some other ****. Tom sells the parts needed as well just ask him and you can find the upper and lower later. 3.8mustang.com have a few people selling splitportswap kits i'm looking at one myself right now their dude.
zinsavage123 is offline
Old 05-12-2009, 05:56 PM
ramoyer1
ramoyer1's Avatar
I have all mine but the lower and the fuel rail and i only paid 200 so far
ramoyer1 is offline
Old 05-12-2009, 06:46 PM
my94pony
my94pony's Avatar
i just bought the heads and upper intake with the throttle body, im looking for a list to get everything else. i have a mustang auto salvage yard only a few miles from my house so im sure with a list i could make one stop there and be done.
my94pony is offline
Old 05-12-2009, 07:15 PM
ramoyer1
ramoyer1's Avatar
94-98 Single port heads
- 4.2 shortblock
- Single port heads/fuel rail/intake
- Mustang 3.8 water pump
- Auto trans = 4.2 or 01-up flexplate
- 5spd = 01-up or rebalanced 3.8 (0 or neutral) flywheel and a pilot bearing
- V6 Mustang bellhousing
- Re-use your stock cam position sensor
- 01-up 3.8 oil pan
- 01-up 3.8 oil pick-up tube and screen
- 4.2 damper or 01-up 3.8 damper (use the 01 pulley for blower cars)
- Re-use the stock 3.8 oil pressure sender and tube
- Re-use the Mustang headers
- You can use the 4.2 or 3.8 dipstick. Just keep track of where 5 qts puts the mark when refilling with oil.
ramoyer1 is offline
Old 05-12-2009, 07:48 PM
weazle23
weazle23's Avatar
so you have to pull the tranny to do the split port swap?
weazle23 is offline
Old 05-12-2009, 09:10 PM
my94pony
my94pony's Avatar
- 4.2 shortblock
- 01-up 3.8 oil pan
are you sure this is the list for a split port swap you have 94-98 single port heads listed and nothing i see listed on supersix's site is there
my94pony is offline
Old 05-12-2009, 10:18 PM
pdub42
pdub42's Avatar
heres the parts list:
-97+ f-150 V6 heads or 99+ mustang v6 heads (including valves/springs)
-97+ f-150 v6 lower intake, or 99+ v6 mustang lower intake *
-99+ mustang v6 upper intake **
-99+ mustang EGR tube and valve (f-150 tube will work)
-99+ Throttle Body
-TPS sensor for TB (1-CX-1488 from Ford) if not already on TB
-Throttle cable from 99+ mustang v6
-Modified fuel rail that has a universal fuel pressure regulator, and a return line. (available from SteveC) ***
-Accelerator Bracket (F4SZ-9728-B) if not already included on upper intake
-99+ mustang v6 coil pack and wires (your stock coil pack will work too)
-99+ mustang intake tube, or any 99+ mustang CAI kit
-99+ mustang cooling hoses (including the ones going to the heater core) and pipes. You can also make your own lines, by using plumbing elbows,hoses and clamps, and fab it up yourself. (Definately get these if you can.)
-16 a.w.g automotive electrical wire
-teflon tape, pipe sealant, RTV
-99+ head bolts/studs
-head gaskets (I recommend 99+ mustang gaskets)
-99+ upper and lower intake manifold gaskets.
-99+TB gasket
-94-98 IAC gasket
-94-98 valve cover gaskets(reuse the 94-98 valve covers, valve cover gaskets can be reused if removed carefully)
-94-98 exhaust header/manifold gaskets
-you can reuse the 94-98 headers ****
-use the 94-98 IAC since the 99+ IAC has a different connector (Edit: I found that the IAC I used from a 99 mustang had the SAME connector. I am not sure about other years or F150's/windstarts, but the 99 IAC will work and I recommend using it for a cleaner looking install.)
-rad fluid, oil, filter, new spark plugs
-gasket remover, thinner to prep parts before applying new gaskets
parts list taken from the writeup over on 3.8 mustang, great write up
http://www.3.8mustang.com/forum/showthread.php?t=95288
pdub42 is offline
Old 05-12-2009, 10:44 PM
ramoyer1
ramoyer1's Avatar
opps i copyed the wrong list
ramoyer1 is offline
Old 05-12-2009, 10:46 PM
jthorn9
The Godfather
jthorn9's Avatar
-99+ Throttle Body
-99+TB gasket
-94-98 IAC gasket
Yep, that's pretty much everything you need, in short, hit a few junk yards up.
jthorn9 is offline
Quick Reply: split port swap kit
