Is there a T5 write up???
Old 07-07-2009, 06:40 PM
winner99
winner99's Avatar
Default Is there a T5 write up???
I need to change my throwout bearing. Is there a write on this anywhere or can anyone tell me if I'll need any long extensions? I dont feel like taking it all apart to find out I cant reach one bolt.
winner99 is offline
Old 07-07-2009, 07:21 PM
Fink
Fink's Avatar
have extensions just in case. better to be over prepared than to be under prepared.
Fink is offline
Old 07-08-2009, 02:43 AM
PNYXPRESS
PNYXPRESS's Avatar
I have pulled my tranny twice now, both times for throwout bearings. You dont need extensions but it makes things much easier to remove the bolts using a long extension with a swivel and a impact. Just use a ratchet on install though since its quite easy to strip out the aluminum threads. Also you dont need to remove the bellhousing if all you're replacing is the throwout bearing. Makes it much easier.
PNYXPRESS is offline
FivePointToTheOh
03-09-2020 10:26 PM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
2015Ecoboost
09-17-2015 01:48 PM
algregory
09-11-2015 11:44 AM
Quick Reply: Is there a T5 write up???
