what is this?
what is this?
what is this hose? im in the middle of doing a split port swap and this hose is in the way of the upper intake manifold connecting to the lower. im guessing i need one from a 99-04 v6
im talking about the metal hose going straight down the middle.
as to the other post this is a picture of a 94 v6 engine and all i need to know is the name of that metal pipe
its a heater core tube. I broke mine when i pulled my engine out. if you follow it back it will go to the firewall where it connects to another tube, there are two tubes there, I would spray wd40 on it cuz its a B***h to get out.
Yep, it runs to the heatercore behind the passanger side of the dash. It's used to cirulate coolant. If you break it, you can run a high temp soft line in it's place. Much cheaper to do that buy that part from Ford.
Yeah, just cut it at both ends, remove the solid pipe and replace with a soft line. That's what i did. i'll try to post up some pics later today.
